Old 21st March 2017, 06:57 PM
Old 21st March 2017, 06:59 PM
Goran - did you make provision for the clutch pedal switch? I've just thought about that - its needed on manual models to encourage the ECU to let engine speed drop, and also to disengage the cruise control. Some wiring would be needed in a D2 to hook that up obviously.
Old 21st March 2017, 07:41 PM
tps said £4370 retail and £4064 trade + vat
audi huddersfield £4370 and £3933 trade so my discount isn't as good as yours Neil, its a lot more expensive up north don't you know!!!!
my manual parts hunt has so far failed at the first hurdle i can't find a gearbox, missed one at weekend at our sponsors.
cheers Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 21st March 2017, 10:00 PM
cheers Dave
There is an Allroad gearbox in Germany looks to be a 01E, but a bit pricey.
http://www.ebay.co.uk/itm/Audi-A6-4B...oAAOSwTuJYuTwW
Oops, Allroad has the wrong final drive, 4.375
Although it has a better 2nd gear ratio, the S8 01E (DGV and FRN) 2nd is 1.889 and I can tell you its too long, it struggles under 2500rpm when really it needs to be useable from 2000rpm. Using 1st to crawl in traffic above 2000rpm is horrible, too jerky.
Allroad ratios here. Mental 1st gear, 3.75! That would be one fast car from stop.
http://www.audizine.com/forum/showth...llroad-gearing
Old 21st March 2017, 10:13 PM
One here too, need to find out gearbox code to check if its the 4.111 final drive
http://www.ebay.co.uk/itm/Audi-A6-Av...IAAOSwPCVX~P1K
Old 21st March 2017, 10:22 PM
Here are the A6 gearbox codes and ratios from Elsa. I dont know if this list covers all the 01E versions for the A6, there may be more?
Old 21st March 2017, 10:44 PM
Thanks Goran they are close enough to me. In fact I've been there it's amazing! I was delivering on the same road and while I was looking for my drop I stopped Outside, just looked up at the breakers yard and the very first car I saw half burnt out Ferrari F40!!!! That got my Attention and then I looked at the next car and the next they where all Ferrari's about 50 of them. The next racks had Porsches, TVR'S a amazing supercar breakers! They even do aviation.
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 21st March 2017, 09:43 PM
Yes, the simplest option would be to bolt or weld on a short piece of aluminium angle onto the existing pedal box side bracket. Here is a rough sketch on the photo of the rhd pedal box. It needs to be checked how much room there is to go outward above the clutch pedal before hitting interior trims such as bottom of the dashboard. It only needs a few cm so I think it should be ok.
Name:	Pedal box in A8 shell switch bracket.jpg
