Old 16th October 2017, 04:01 PM
There is a very useful diagnostic mode in the ECU whereby if you read a particular measuring block it turns the O2 sensors off and runs open-loop on the MAF only. If it runs like crap at this point, or indeed anything other than perfect, the MAF is failing and needs replacement.
MJ, is this within VCDS? Would be interesting to know where. I've run the other tests on the MAF in VCDS, and everything was within tolerances, but always handy knowing about other tests available.
Tags
5hp24, gearbox service, transmission, valve body
