Old 20th December 2017, 08:28 AM
Mine are too, new bulbs didn't help so much. I polished the coating off the outsides due to aging but the inside optics are milky. It's not really the time of year for sticking some microfibre in the back on some wire as I have sene on youtube. Were yours cloudy inside or outside?
If you do change the bulbs, just do one first and then see what the difference is, otherwise you will never be able to decide if it is placebo effect. To change them you really have to remove the front wheel arch liner and this is easier when it's warmed up a bit rather than stiff and cold.
Once the liner is moved you can steer the wheel out of the way and access is very easy if, not the airbox and power steering reservoir may need temporarily moving.. Doing from under the wheelarch is much easier even if it sounds difficult.
