Old 17th January 2018, 01:47 PM
How are you seeing the car going to sleep ? Is it by looking at hazard light back lighting ?
Old 17th January 2018, 01:55 PM
ChiefUno ChiefUno is offline
That and the backlighting by the gearselector
Old 17th January 2018, 02:57 PM
neeldub neeldub is offline
Return the MOST system back to normal. I am certain that it's the handles that's causing the issues.
Also make sure that the battery is correctly coded to the car.. providing that the battery is a genuine VAG one and intended for your car.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 17th January 2018, 04:31 PM
The battery is coded and working. I´m sure that is not an issue here as I previously had it done by Audi
By returning the MOST back to normal you mean just leave it as it is right?
with out the loop.
But how do you explain that the car enters sleep mode when I pull a fuse?
Old 17th January 2018, 04:55 PM
yes return the most back to factory specs and replace the handles.. that should cure it.
Previously:
Currently:
Old 17th January 2018, 05:06 PM
I´ll give it a go when I have the money for 4 new handles
Might check wiring first tho
Old 17th January 2018, 06:52 PM
On a day when your door handles have dried out, put tape across the buttons to seal them. Then wait for the rain and see if the battery drain persists
Old 17th January 2018, 11:29 PM
Have a look on ebay for the handles.. you can always have them repainted. Or you can get a brand new one, primed, from TPS from £96
Previously:
Currently:
