Old 19th February 2018, 08:03 AM
pete-p's Avatar
pete-p pete-p is offline
Two questions:
1. How did you get that first picture?
That was fairly easy, I just slid my phone in on top of the ECU box, it took a couple of attempts to get it right. I just had to be careful not to push it in too far! So the first picture is looking down from above.
2. How did you find the hole and feed the well nut in?
This wasn't too easy but using the photos in this thread http://forum.a8parts.co.uk/showthread.php?t=7645&page=2 I was able to work out the location from the two grommets and a seam in the body. A little light scraping with a long screwdriver soon found a hole. All I removed to gain access was the ECU box lid and undid the nut on the windscreen trim so I could lift it out of the way.
To get the well nut in was a little tricky as I didn't want to drop it but using some tissue paper to hold it onto the end of an allen key and some long nose pliers (I didn't have a long enough allen and had to buy longer ones to finish) I was able to drop it in place and used a long screwdriver to help push it in and off the allen key. It took patience and some care to work out the easiest way around the pipes without losing the nut. I also positioned my phone to shine the torch light so I could see better.
I didn't scrape a single knuckle either! Time will tell if it stops the water ingress or if the drains are also blocked, but it looked fairly clear of water in there.
Cars...
Old 19th February 2018, 09:15 AM
You must have done it wrong if you didn't even scrape a knuckle. If a job is worth doing right, it's worth bleeding for.
Old 19th February 2018, 09:25 AM
Excellent, those little details are what we need.
If I tackle it and find a better way I'll explain it here.
Well nuts are a handy device, especially with the electrolytic corrosion issues we have to beware of. I used them to secure my reversing camera.
Old 19th February 2018, 09:45 AM
pete-p's Avatar
I did wonder, I usually drop something somewhere I can't reach or manage to draw blood but not this time!
The well nut made it much easier I'm sure and there's no risk of corrosion as you say, I used a nylon washer supplied with the nut just to be sure. I think it would be fair to say the hole is almost directly below the bend of the A/C pipes, the orange grommet was my main guide though.
Cars...
