Old 9th June 2018, 03:11 PM
Presume you're mainly looking just to see if it's the right sort of car for you and your wife?
If seriously considering buying then:
Check s-tronic service done on or before schedule (38k advised on mine)
Ideally annual services, but most are on longlife
Plugs should be done around 57k/6 years
Supercharger belt is due at about 60k miles (and might as well do the auxiliary belt at the same time, as it involves pulling the front end into the service position)
These are based on a pre-2012 so the service book may indicate a different interval (or in the case of the supercharger not quote an interval at all!)
My invoice for spark plugs quotes £12.99 each for them, but we had the car on a service plan which covered the cost entirely so labour isn't broken down.
The only fault ours has suffered from is a failed thermostat at pretty much bang on 50k miles. Not sure if later cars suffer with it, but the supercharger needs removing to change it. Ours was covered by the warranty (circa 6 hours labour to change according to Audi book)
Report back soon!
