Old 9th July 2018, 12:19 PM
Thanks HP, yes, I do have the analogue TV tuner on my RNS-D. Would you mind giving me a link to what I would actually need?! I'm pretty dumb about this stuff!
Old 9th July 2018, 12:43 PM
Check out the following thread:
http://forum.a8parts.co.uk/showthread.php?p=65026
Old 9th July 2018, 02:52 PM
There are two types of TV tuner, with different connectors. Check which one you have first.
The older type had direct individual socket inputs as I mentioned above, sorry but I forgot about the later version described by Sean.
Old 9th July 2018, 03:55 PM
Thanks Sean and HP, that's really useful!
Mine is Sept 2002 reg so without checking the VIN I'm pretty sure it's a TV Tuner B version.
That being the case, can someone provide a link to the required input cable please?! I'm bad enough with car mechanicals, car electrics really are beyond me!
There are things that I am rather good at, this isn't one of them!
Old 9th July 2018, 05:21 PM
It appears my link in that thread no longer works, so try here:
https://www.kufatec.co.uk/shop/en/ca...apter-tv-tuner
Old 9th July 2018, 10:26 PM
Thanks Sean! Good on you sir!
When it's all done I will post up some piccys to share what I went for in the end. Having this car has turned me into a child again, yay!
Old 11th July 2018, 01:17 PM
Where are you going to mount the camera?
