Old 20th December 2018, 03:43 PM
Originally Posted by Markiii View Post
on a related note anyone have a link to removing the door panels?
Check out the 'Retrofitted Rear Blinds' in my signature below.
Old 20th December 2018, 04:54 PM
This is an interesting debate, but my thoughts (having taken the door apart for other reasons using Sean's guide) is where do you put anything?
It's all pretty tightly packed inside a D2, and the only "decent" sub I've seen described is MJ's which IIRC is in the boot and uses the ski hatch to emit sound into the cabin.
Plus if you take a door apart you WILL need at least some of the door card clips (they break) and I thought I read somewhere that they're NLA.
I've taken an "executive decision" having "upgraded" from a PF S8 with Bose to a non-Bose FL S8 to stick with OEM and enjoy the engine......
Old 20th December 2018, 05:51 PM
The door clips are still readily available. Part number is 4D0867299D. Around 60p each from Audi, but can be bought cheaper elsewhere.
Old 20th December 2018, 09:32 PM
Markiii Markiii is offline
Answering my own question about door panel removal
http://www.audipages.com/Tech_Articl.../doortrim.html
Old 22nd December 2018, 09:13 PM
was anyone able to confirm the speaker sizes?
I was going to pull the door panels and take a look but MiL is not well so last minute diversion to Ireland for Xmas has left me unable to do anything hands on.
research will have to suffice until the new year
Old 22nd December 2018, 09:18 PM
https://forums.quattroworld.com/a8/threads/7344.phtml
suggest the front woofers are only 4" but can take 5.25" with a bit of a trim.
surprisingly small if true
Old 22nd December 2018, 09:23 PM
which would seem to backed up by this
https://www.audiworld.com/forums/a4-...-bose-2888688/
Old 24th December 2018, 08:39 AM
hunker7 hunker7 is offline
10cm in the doors, but I'll personally be fitting 13cm in original enclosures. Deck is 6".
Old 24th December 2018, 09:46 AM
13cm in the original ported enclosures or direct on to the door card? I did think about printing an adapter to allow a larger speaker to be mounted to the door card, but thus far I haven't exceeded the capabilities of the original ported Bose units when backed up by a decent amp and subs.
