Is this with the AFS lights? I have an intermittent fault with mine, and is stems from a fracture in the wires inside the headlight unit, caused by light swivelling and the wiring being too tight.
There is a fix but it requires a competent person opening the headlight unit up. I think there is a write up somewhere, I believe the wires are either too short or cable-tied in a place that reduces the slack. A new headlight will obviously have the same issue but I suppose at least it would work for a few years before fracturing through use..
'09 D3 S8 - Most of the bells and whistles (B&O, Audi Exclusive brown interior and exterior paint, soft close, ACC etc) de-flapped manifold! |
That's exactly the problem. I had considered replacing the cable tie on my good one, so that there is a bit more slack in the wire. As for the other one, I'd thought of repairing the wiring, but it depends if you could get the connector and wiring out far enough to work on it, without having to take the headlight apart.
Could be taught cables... Although with the same symptoms on mine, it was the headlight control module.
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment ![]() 2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot 2022 Mercedes EQC 400 Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS 2008 A8 3.0 Tdi sport, B&O |
So my gremlins have returned with a vengeance, the entire car cut out for a micro second, lost all power whilst on the M40! I properly sh1t myself!
That is bloody dangerous and not sure really what to do now. I got home but the electrics are all over the place, central locking, interior & exterior lights, startup sequence, needle sweep, all glitchy. I am thinking either loom damage somewhere or water somewhere. Where are the drains located again?
Possibly a stupid suggestion, since I know nothing about D3s, but could a bad main earthing point be the cause?
Actually I think you might be on to something. I wonder if there is a test for that?
