Go Back   A8 Parts Forum > General Natter > Owners Meets
Owners Meets Any info for any meetings, events, track days
Old 5th June 2019, 09:49 PM
Hi all,
For those who haven't been before, the workshop is at Copplestone Mills Business Park, EX17 5NF. I'll put General Vod out the front so you can see him from the main road.
If you come off the M5 at J27 and head through Tiverton you'll come down the A3072 towards Crediton. Just as you come in to Crediton your satnav will try and turn right off the main road. Ignore it! I will put a sign at the junction like this:
Go straight on in to Crediton, straight over a mini-roundabout, and then continue to follow the satnav
If you want fuel, turn left at the mini roundabout - there is a Tesco supermarket with Momentum just over the hill and a Shell garage to the right of it with V-power. After fuel, continue with the satnav.
Green is the likely satnav route. Purple is fuel. Satnav may also take the A377 Union Road.
The same applies for those going direct to the New Inn as the turn for that is on the route to the workshop.
