Old 18th June 2019, 04:04 PM
I would think that the inner ring is a support to stop the exhaust from being collapsed by over enthusiastic spanner use on the clamp bolt.
But from those photos I cannot see how the chrome tip is held.
Is it in fact just a push fit?
Old 18th June 2019, 06:02 PM
The chrome tip is welded to the middle ring (one spot at the top back which you can just about see at the 12 o'clock position and one spot at the front inside lip), as are the two parts of the clamp.
From the shape of the inner ring, I was thinking that it was to allow for better alignment of the exhaust tip.
Old 18th June 2019, 07:41 PM
I always spray Dr Magic/Oven Pride into them on my TDI, it foams up and drips out black. Leave it overnight and then hose them next time you clean the car - repeat 2-3 times. I do this annually before the MOT so they think the DPF has no 'issues' as the inside become completly clean silver metal again..
https://www.hihouse.co.uk/dr-magic-o...l-cleaner.html
Old 19th June 2019, 12:11 AM
H-M3 H-M3 is offline
Get some 00 wool wire and some nitrol gloves and get scrubbing with barkeepers friend
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 9th September 2019, 04:35 PM
irelandbuyer irelandbuyer is offline
Hat tip to Snap dragon on the oven cleaner tip. I taped off the bumpers and gave a liberal spray of BBQ cleaner, outside and in. Left for about two hours and put newspaper underneath. I bought a bottle scrubber, took off the handle and used a drill to clean the inside of the tips with bucket of hot water to dip the brush in and clean as i went. Then i hit it with t-cut metal polish. Took me less than 10 mins per exhaust tip.
Compared to the hour or so I see detailers using tons of metal polish this was a super hack. The BBQ cleaner literally hoofed the carbon deposits off...
Nice one Snap...
ID:	22133   Click image for larger version
ID:	22134   Click image for larger version
2007 Audi A8 D3 3.2 FSI
