Old 19th August 2019, 04:08 PM
Originally Posted by Audi Doody View Post
fingers crossed it's not the throttle body as they're big bucks aren't they
Oh and the cruise control switch was flagged as broken- makes sense as cruise control doesn't work - do I just need a new stalk?
Check out the site sponsors on eBay (a8parts). They have several starting from £28 if you want to go secondhand. If you want to purchase new, give them a call on 01642 783537, as they can order them in.
They might even have the cruise control stalk.
Old 19th August 2019, 04:14 PM
Cruise control has two fundamentally different versions, which depends on the age of your car. As I think is flagged prominently on the forum, it helps if you supply more details of your car as answers do depend on precise vintage, trims, etc.
Old 19th August 2019, 08:17 PM
Audi Doody Audi Doody is offline
Ah ok makes sense:
W reg (2000) 2.8 FWD. Not a sport although has 18" sport wheels
Old 19th August 2019, 08:32 PM
2000 should be the "drive by wire" throttle where cruise control is just a bit of software in the ECU. Earlier versions actually had a separate box in the engine bay ECU box and that really could go wrong.
As such, with DBW, the switches on the stalk talk directly to the engine ECU and are pretty simple.
They often get gunged up, spraying with contact cleaner and energetically exercising them can often bring them back to life.
Unless of course they really are broken, but all that VCDS (or any other diagnostic) can tell you is whether it sees the switches operate, not that they are "broken" so this is always worth a try.
Do any of the cruise control functions work ever? Mine didn't when I got the car and it was the end button that wouldn't "set" a speed, so it never worked until I cleaned and "exercised" it.
Old 19th August 2019, 09:47 PM
That's interesting, I'll have a play with the set button. Thank you!!
The previous owner mentioned that the 'set' button worked, but you could increase the speed. None of the cruise control has worked since I've owned it, which is since May only. Best car I've ever had for motorway duties.
Old 19th August 2019, 09:52 PM
Mine's still not great on increasing speed (or resuming), sometimes it just disengages.
So I'm more in the habit of increasing with my right foot (which is actually easier than that horrid little slider anyway) and pressing set again.
I think my slider switch is the least reliable bit so I just leave it permanently in the "on" position. Beating the hell out of the end button got mine working reasonably reliably in the end and you can live without the rest.
Old 20th August 2019, 11:48 AM
The garage have stated that the faults are from the throttle body, so a new one is being fitted. £350 for a new genuine Bosch item. The main dealer wanted 900 quid!!!
