I've mentioned Evapo-rust in a couple of threads today so thought I would expand on it. Its a relatively new to the UK rust-eating solution that is, as far as I can tell, magic. Its not acidic, not alkaline, not phospor-based, biodegradable, safe to handle, and non-toxic, yet somehow rusty steel comes out completely clean, usually after just an overnight soak. Scrape off any chunky rust beforehand obviously so it has less work to do.
![]() Available on Amazon here, it comes in various sizes but the only one which makes financial sense is the gallon. Pour it in to a plastic container and let it do its thing. It doesn't affect paint, rubber, plastics or aluminium. I can find nothing online about how this stuff works (ergo magic), but its rapidly becoming ubiquitous. Almost all the youtube automotive or engineering channels I watch are using it for cleaning or restoring tools, car parts, machinery etc. I've bought two gallons so far, cleaned loads of things with it, and its still working. There's a bunch of sediment in the bottom of the container which I decant every now and then, and its changed from yellow to green, but its still as effective as it was when it was new. The gel is less effective and substantially more expensive so I don't use that much, but if something can be dunked in a bucket, game on ![]() |
Only if you can get the Range Rover in a bucket Dezzy. But if its that far gone you can probably get it in a bucket
https://www.thompsonsltd.co.uk/qevp5...r-soluble.html It's listed there at £21.59 (ignore the silly RRP they give), and because I live in NI, I always get stung for additional shipping charges, so I always shop around.
![]() The MSDS Attached) doesnt give its composition - just has it as a "chelator/detergent" - but it does seem to be remarkably benign for something that eats rust. ![]()
Good spot on the 5 litre one
![]() I've got a brake caliper bracket soaking overnight for a before/after shot ![]() |
Thanks for the tip MJ.
![]() I'm guessing that whatever is in the stuff likes oxygen (even more than iron does) and is able to react with the oxygen in the iron, removing it and therefore reversing the rusting process. But presumably that would make it react with the oxygen in the air too, causing it to become saturated if not kept in a sealed container? .... unless it somehow reacts only with certain oxides ...
