Old 7th September 2020, 07:59 PM
It used to be a common D3 problem where the light strips would fail, but that would be on 1 door. You are implying that all 4 doors light up, but then all go out at the same time ?
That would be harder to fathom, as I'm 99% sure the light strips are driven off the door controller module (which also does central locking, soft close, other lighting etc)
That module, in each door is definitely where I would start.
Old 7th September 2020, 08:52 PM
Versace Versace is offline
I have tested the roof electronics control module, only one code as always, also when the lightning was working.
004 - no signal communication/intermittent
Then I went to the door control module, run the output tests and walla, the ambilights work. As soon as I turn the output test off, it stops working. The same for all four doors and their control modules. So the lightning itself is working.
Tried the button on the overhead panel, no luck, but the button itself works, I have tried it with the “City” mode.
Otherwise 270.000 miles and still going strong!
What could possibly be wrong?
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 8th September 2020, 12:24 PM
With everything checked and working but still getting that intermittent error code, have you checked the connectors to ensure they're seated properly and don't have any signs of corrosion in them?
Old 8th September 2020, 05:24 PM
No, I will take the module out once this week. But still interesting how this is even possible that while testing, everything works just normal.
S8 D3 FL II.
