Old 23rd November 2020, 07:56 PM
I'm hoping that full rear setup that Ronin found recently is viable. I'll probably order a set after this one is done
Back on its wheels for the first time in two months! No error codes either
Went to attach the new plates and discovered the PO had glued the rear on with silicone which is a novel approach
I mechanically removed as much as I could and have left it soaking in WD40 overnight so hopefully road test tomorrow.
ID:	24626   Click image for larger version
