#51
All's well in the world again.
![]() Maybe he should be called Admiral Vod until his suspension is sorted.
#52
#53
Good to see you're working on something that's better for your state of mind
![]() I think Admiral is a bit high ranking. Commodore is more appropriate and also suggests an affinity with the Holden Commodore familiar to some of our Aussie friends which definitely corners like a boat ![]()
#54
I'd suggest consulting our Librarian for appropriate naval appellations
![]() MJ Your threads are a the best antidote to lockdown tedium ![]()
#55
The suggestion that VOD is more akin to a naval setting has merit. Given its place of birth I would suggest the German Naval rank of Kommodore.
Kommodore VOD von Großluxobarge a nice ring to it.
#56
I vaguely recall that The General was a runabout for you but maybe going to be sold. Is it still part of your extensive stable or did you manage to get it out of the door before the latest lockdown?
#57
Bert bought him back in early 2020, right before lockdown started
#58
This thread has been my inspiration for getting the water out of my Dolph over the past few weeks.
Looking at General VOD with The D2 sport alloys fitted reminds me how good they can look. From an aesthetics perspective they are perfect for the car. Same as the D2 S8 Avus wheels. The design is timeless. I really would love a set of either wheel design in a 9x19 or 9.5x19.
#59
![]() The backbox is being replaced with a Supersport (same as on my S8) to release some of the lovely V8 burble without being too obnoxious as a daily. Cut the original system under the subframe so it can be fitted with sleeve-clamps The backbox is fine so that'll go on the shelf in case it needs to go back on in the future The supersport box doesn't clear the towbar, but luckily I solved this on my S8 so I already knew what to do - cut a gert hole in it ![]() Made a filler plate of stainless sheet As most of the left hand bracket went away, I reinforced it with a bit of stainless bar Filler piece tacked in. This will get tigged in place by Craig from Ally Cat in Crediton (who welded Ricky's Green Beast) The rear calipers are working perfectly, but are not looking very happy. This odd shape on the piston boot is indicative of corrosion in the groove where the boot sits, pushing it out of the caliper housing. Cleaned up. Its only a matter of time before this pops out and then the caliper seizes up, so both will replaced with new TRW units. It wasn't any better with the piston pushed back. Removing the piston, cleaning the groove and replacing the seals would solve this, but given Vod needs to be home in a week and replacements cost less than the time and parts to repair the old ones, its not worth it. While the rear end is in bits and we're looking for handling improvements, I might as well replace all the control arm bushes as they were completely toast These haven't seen the light of day for a long time! I think he was probably only on his second set of rear discs. Cleaned up nicely with the wire wheel Empty wheel well! Once the mud has dried out a bit I will clean this up a bit before reassembling everything |
#60
would you mind sharing a link for the alternator bearings? I already have a new regulator waiting so new bearings would be awesome!
