Old 3rd March 2021, 10:25 AM
If VBulletin doesn't then the "URL Rewrite" module of IIS will fix this
I'm ashamed to confess what version of Windows we're talking about here, but the IIS you're thinking of, and this one, worlds apart....
A simple 'URL' redirect of anything hitting HTTP to the root HTTPS would break whatever link people were trying to visit so I had a brief look at the time and parked it.
I knew it would rear its head again one day, and here it is....
Old 3rd March 2021, 10:39 AM
Glad to hear you're on it, but can't help at all as it's not my bag, but just wanted to say that it's only a minor nuisance, even though it's happening more frequently - nothing on here is time critical, well not for me, anyway...
Old 4th March 2021, 12:10 PM
Thats OK for you then, I had to speak to my wife about stuff unrelated to cars on several occasions recently
Old 4th March 2021, 02:56 PM
hahah, I feel a great weight bearing down on me....
fwiw, I did actually buy and download the latest Vbulletin software last night, so that's a step forward.....
... probably not going to improve things much just sat in my download folder though, but I feel accomplished...
Old 5th March 2021, 10:06 AM
Not as much as when it comes to actually installing it.
You'll have a bunch of people sitting here twitching at their keyboards and checking the time every few minutes in anticipation.
Old 5th March 2021, 10:30 AM
I'm curious what the upgrade process actually is. Are there a bunch of scripts to run in MySQL? Presumably the PHP stuff is just drop the new files on top of the old ones? Is all the config in the database?
If you're moving to a new server at the same time can a test version be spun up in parallel to the live version?
Old 5th March 2021, 04:06 PM
Vbulletin has to go from 3.8 -> 4.2 -> 5.x
Windows has to come into supportability at least.. ;-)
MySQL and PHP will no doubt need updating hugely too.
There will definitely be parallel testing, to make sure that the upgrade hasn't broken anything, before performing it for real, so consider yourself volunteered for that test phase
Edit: I didn't really answer your questions! - I assume there will be lots of DB scripts to alter the schema, but not looked yet. I also assume the php bits will just drop in..... The database is key. You can run everything in the DB, or run attachments as separate files. We currently have separate attachments, although they recommend you move attachments back into the DB for any sort of migration work, which makes sense, but I suspect we have gathered a lot of attachments over the last decade... !
It will be a few weeks yet I think unfortunately. Royal Mail have thrown us some curveballs on their APIs post Brexit, so need to finish sorting all that out first.
Old 3rd March 2021, 10:48 AM
Well, I'm sure that you'll be building a shiny new Server 2019 machine for the shiny new vbulletin, so you'll have a shiny new version of IIS with URL Rewrite...
URL Rewrite runs within IIS and uses regex to dynamically change the request, so if a link on the forum points to http://something IIS will accept the request, rewrite it to https://something, and vbulletin ought not to notice the difference.
Probably...
Old 3rd March 2021, 03:19 PM
Exactly this, think it came in in IIS7 - so many moons ago, and prior to that you could use a 3rd party filter (free) in earlier versions that did the same thing..... I'm assuming it isn't NT4 still?
Old 3rd March 2021, 04:53 PM
I hate these foriegn language threads.
If I had the power I'd send you all to a room where you could talk dirty without annoying us mere mortals!
