Old 20th April 2021, 09:56 PM
Lots done tonight.
I made a new headlight level arm from scratch
Are you putting the D2Doctor logo on these items?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 20th April 2021, 10:04 PM
That clamp looks like a 3D-printer special.
As for the rest of it, there's a hint of "can I build a complete S8 from all the bits I've got lying around"...….
Old 21st April 2021, 07:19 AM
Yes, the clamp is printed hence the bright orange. Thats my prototyping filament since its much easier to see details in bright colours.
I'm not going to be selling these in the near future as I need to see how it holds up to regular use as it is in a very harsh environment. This is something I'll keep in the toolbox for when the metal clamps can't be reused.
By the time the murple is back together I will have effectively built a complete S8 from bits I've got lying around, since the only things which won't have been replaced will be some of the glass, some of the purple panels and three of the tail lights Oh and maybe the fuel tank. Captain carnage doesn't appear to have been near that.
Old 21st April 2021, 06:12 PM
Sounds like a new edition coming up. The TBE......Trigger's Broom Edition
Old 21st April 2021, 06:55 PM
I called it Trigger to a young Polish friend the other day and he was very confused until I explained it Three engines, two gearboxes, its had four sets of wheels mounted and hasn't even left the yard yet!
Old 21st April 2021, 08:40 PM
Quite a small update today since it was a lot of work for not many pictures.
The LHD wiper motor it had on the left, and a RHD motor on the right. Just a mirror image of each other, except the LHD version doesn't actually fit the RHD mechanism.
I then spent the next hour sorting through wiper racks to find a good set of parts, and then a further hour assembling a working rack.
Before fitting it I made a start on cleaning the rain tray / scuttle area. The crud below the electronics box is an inch deep
I don't have time to take the electronics box out right now so I'll have to vacuum up as much of this as I can, then get the rest when I do Botang's hole and the noisy hvac pump.
43 hours
Parts used:
PS hoses (refurb, £200)
PS hose brackets (used)
NSF upper rear arm (used)
NSF lower rear arm (used)
NSF wheel bearing (used)
CV boot (£12)
Suspension brace (used)
Boot lid (£150)
FE wheels (£500)
Window motor (£50)
Headlight level arm joints (£15)
Radiator (£300)
Belt idlers (used)
Accessory belt & idlers (used)
Snub mount (£60)
Air filter (£6)
Wiper mechanism & motor (£120)
ID:	26230   Click image for larger version
Old 21st April 2021, 09:18 PM
Ronin Ronin is offline
I thought my wiper motor was bodged with some black sealant, I see it was a factory process just like the garden hose for head light washers
Old 22nd April 2021, 12:37 PM
If anyone can, the D2 Doctor can. To be honest, that's a contributory factor to me keeping Herman, having a fairly high degree of confidence that MJ can sort it.
It also reminded me of this funny/desperate "looking for" post on my Panda 100HP forum:
"Hi has any one got a driver and passenger seat. Steering wheel. And gear knob. Hopefully in the south of England.
Also looking for unicorn. Rocking horse poo. And a large dragon."
The joys of maintain old cars
Old 22nd April 2021, 05:02 PM
They missed out on the hen's teeth to complete the set.
Old 22nd April 2021, 08:29 PM
I finished cleaning all the detritus out of the rain tray, or at least as much as I can with the ECU box still in place, then put the wiper linkage back in
Then on to the engine. I cleaned up the plastics, and replaced the airbox trim and intake duct, then its ready for the front panel to go back on.
Front panel and radiator back on and hooked up. Its amazing how much better (quieter) the engine sounds with all the worn out accessory drive rollers replaced. The alternator is a bit noisy but that can be tackled when the engine comes out later.
Getting through the list. Still a bunch of jobs to get an MoT though.
47 hours
Parts used:
CV boot (£12)
Boot lid (£150)
FE wheels (£500)
Window motor (£50)
Radiator (£300)
Belt idlers (used)
Snub mount (£60)
Air filter (£6)
Air box trim (£10)
Intake duct (£10)
ID:	26233   Click image for larger version
ID:	26234   Click image for larger version
ID:	26235   Click image for larger version
