#41
Looking good MJ
Be so much easier to get the new O2 sensors in with those manifolds out of the car |
#42
I love these posts Michaela
#43
There's a level of thought, understanding, creativity and engineering "sympathy" evident that you will never ever find at a dealer and probably not even the very best independent specialist.
#44
A slightly frustrating weekend as the timing belt still hadn't turned up so there was a limited amount I could do.
Flipped the engine back over once the sump sealant was dry As usual the temperature sensor was rusted in place, so had to be destroyed to get it out. Pretty crusty Cleaned up ok The coolant pipe o-rings were also pretty crusty Replacement link hose and powdercoated coolant pipe No amount of elbow grease would clean up the manifold, and I had nothing else to do so I gave it a lick of matt silver paint Sunday morning after the paint has dried. New inlet manifold gaskets on, ready for the manifold Manifold refitted Crank oil seal - this was dried up and leaking New seal fitted to the bushing and pushed in place with the purpose-made tool. The manual says to push the seal in place and then fit the bushing, but that is extremely difficult to do without folding over the lip of the seal, hence why I fit the bushing to the seal off the engine so I can make sure its all ok, before fitting both bits together. Old crank pulley bolt at the top, new one at the bottom. It has stretched about 2mm! Stuck now with no timing belt or thermostat Monday - SAI blanks fitted and new manifold bolts The belt kit finally arrived, drop shipped from Poland because there is almost no stock left in the UK ![]() ![]() Mark - this is one of the long nuts which goes through the manifold |
#45
thanks MJ so that bolt, holds on the manifold?
ref what am i looking at there? coolant pipe? green cable ties? |
#46
Hi MJ, why the secondary air injection delete? Is this a manual conversion?
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
#47
Yes. there are a dozen ordinary M8 flanged nuts, and then two of these long nuts which go right through holes in to the manifold.
Thermostat bypass pipe with the bank1 knock sensor cable tied to it, per the factory installation, although the factory used black ties. You get green since I ran out of black ![]() Quote:
#48
If I had know that when rebuilding my S8 it would have saved a lot of swearing and bleeding knuckles!
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify ![]() Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
#49
![]() They're also used when I run out of black ones ![]() |
#50
Forgot I had to go to the office in Leeds yesterday (650 mile round-trip!) so I finished off the engine tonight instead.
New thermostat in place The cover went on without fully removing the belt Tensioned the belt and finished everything off Spec here is 5mm +/- 1mm. New fan bearing and tensioner roller also in place Engine back on the separating table The starter teeth on the original flex plate were pretty trashed after eating bits of starter motor so I replaced it with a good spare, and thats the major engine work complete. All that's left is to put the spark plugs back in and coil packs on once I've spun it on the starter to get oil pressure, and then the replacement wiring harness and coolant hoses go back on when it's reattached to the gearbox. Gearbox on the stand for its service. As this is in very good condition and not leaking I'm leaving all the output flanges alone and just doing the filter and ATF which is a job for tomorrow ![]() |
