Yes, its the front bit with the two black pipes to the right. I don't open the AC for this job - I just swing the condenser off to the side. The AC is still nice and cold
Right, I've got very behind on updates in the push to get the car finished, so this is quite a big one!
I checked everything with VCDS before startup and found that the ECU was reporting a MAF error. Changing the MAF didn't help, and it wasn't fuses, so that meant a wiring problem. Pulling back the boot on the connector soon revealed an air gap! Luckily these terminals fit all sorts of things so I had a spare to hand Soldered and heat-shrunk since there's no room in there for a crimp. Happy ECU and the engine runs sweetly ![]() Both bumper support bolts were seized so I stripped the bumper down and put the brace bar in the vice then cut the heads off the bolts Remove these two T25 screws and the 'nut' complete with the stump of the bolt can be removed and the supports are free Normally I'd try and save the nut, but these will need a lot of work So I cheated and nicked a pair from a spare bumper I replaced the lower bumper with the one Strummagnet found for us, and also a parking sensor, and then put it back on the car I had a slight coolant leak from the one hose I couldn't get new ![]() The air intake on the front panel was broken with all but one of its fixing tabs missing so it just rattled around. Luckily these are still available from Tradition and I have a few sets in stock so this was replaced The car needed a new windscreen which Mark arranged through insurance. I already had the wiper mech and scuttle panel out but I also removed the windscreen trim ready for the fitters and discovered one of the clips had disintegrated This is entirely because the factory put some butyl rubber sealant in the bottom of the channel, causing water to pool up around the clip. Why would they do that? ![]() Then removed the sealant Cleaned the rusty stains off the paint with fallout remover I can't get the rivet gun on the rivets with the glass in place So waited until the glass was out (a 1 hour ordeal for two fitters!) and then rivetted the clip in. I also rebuilt the wiper linkage using bits from a couple of others (the usual drill) and now there are no good ones left so I am forced to get on with my plan to re-engineer / re-manufacture the mechanisms. I have a cunning plan for that so will provide updates on that separately. All finished and a clean pass on the MoT ![]() Wheel alignment tomorrow then its all done and ready to go home ![]() |
Fantastic results, as ever MJ
![]() Car looks fab How were the windscreen fitters? Must admit I’ve avoided using insurer approved fitters for last 3 windscreens I’ve needed…..
New wiper linkages!!
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
As they had, rather optimistically, picked up this job at 4:45 on a Friday afternoon, they were quite grateful that I'd already removed all the trim and so didn't require them to put it back. I'd made a cardboard template of the position of the glass relative to the body so that we could set it in the right place, since the surrounding trim wasn't going back on at that point, and they were happy to tweak the new glass around so that it matched the template perfectly so everything would go back together. I think it was 6:30 by the time they left, although they were on overtime by then so not too miffed! |
That is looking might fine now. Great work as usual
Been a week and a bit since I picked the Dolphin up so thought I should report back.
Typically it decided to throw a couple of last minute new problems into the mix as we were on the way down to collect. Fortunately with sufficient time for MJ to run around like a mad thing before we got there. Arrived to what effectively looks like a brand new 20 year old D2. And to be frank has been driving like one ever since. I'm still finding little Easter eggs that she fixed that I hadn't even mentioned ![]() Thanks MJ and for the late night last minute fix |
I love a success story
![]() After mine was “Doctored” (in a good way) I know how you feel and still enjoy the car more than ever. Hope you have many more years of fun with it ![]()
That's great news. MJ's attention to detail and knowledge of these cars is amazing.
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
