Old 15th July 2021, 02:21 PM
Normally yes, the MoT is the last step before they return home, but with this one being a slightly longer term project the work so far has been simply to get it roadworthy and driveable. With the exception of the interior, mechanically it is now in the state I normally receive them, ie working and driving but in need of some attention.
Parts prices are based on Prestige's pricing for used items, although most are coming from my own stock. New stuff is mostly coming from Autodoc.
I bought it from Bert because a long term rolling resto was the only viable way to save it, since its the last known example of Avus and extended red. It'll be going to a new home when its finished
Lucky new owner . I really think you need to get some "D2 Doctored" plaques to add to those cars that have been through your hands (literally!) - I'm sure it'd add to their future value.
Old 17th July 2021, 09:56 PM
I'm pretty sure this thing is trolling me now
Remember how I said there were no error codes or warning lights?
The bank 1 primary O2 sensor failed on the way to the MoT
So, today was swapping both sensors. You can see the bank 1 sensor here:
In fact no, you can't because the damn SAI valves in the way. Well, they aren't working anyway because the vacuum hoses are all perished, and you can be very sure that if I have to take them off for any reason they aren't going back on!
With the valve removed, you can now see the sensor
Bank 2 sensor - this was still working, but at 170k its pointless changing just one of them, and that may result in the two banks running unbalanced anyway which we don't want.
The amount of stuff which needs to be removed to get to the sensors:
Still, thats better than the D3 where you have to remove the inlet manifold
Bank 1 sensor removed
New one fitted, then the same on the other side
Capped off the SAI solenoid valve. The vacuum supply hose will be removed later.
One of the manifold link arms was broken so I replaced that while I was in there
And since I had to take the upper brace out to get the wiring harness out of the way (for the bank 2 sensor) I put a brake block on it when it went back in
It does run more smoothly with the O2 sensors replaced so they were clearly past their best even before the bank 1 sensor died.
This job took 5 hours, 3 of which was exorcising the SAI valves. That puts the total at 147 hours. Sensors are about £60 each.
ID:	26722   Click image for larger version
ID:	26723   Click image for larger version
ID:	26724   Click image for larger version
ID:	26725   Click image for larger version
ID:	26726   Click image for larger version
ID:	26727   Click image for larger version
ID:	26728   Click image for larger version
ID:	26729   Click image for larger version
ID:	26730   Click image for larger version
Old 18th July 2021, 09:31 AM
Ronin Ronin is offline
the parking brake adjustment is also a lenghty job isnt it? mine isn't holding well and I'll need to get it into a garage its one of those jobs that requries a lift
Old 18th July 2021, 09:47 AM
Its a complete arse since at the very least the exhaust needs to come off. I'm about to try it and see if it can be done without dropping the propshaft...
My MoT guy always complains about D2 handbrakes, but this one won't hold the car on anything more than a gentle slope so this time its fair enough.
Old 18th July 2021, 10:13 AM
My old D2 and also C4 A6 had weak handbrakes but it was mostly caused by the shaft that goes in calliper getting rusty and not rotating freely so that spring was not returning it fully and as the result self adjusting mechanism in the calliper was not working properly. A bit of penetrating oil, good exercise and it was good for MOT.
As for the O2 sensors I saw a nice video on youtube showing how to test them with blowtorch. If you hook up voltmeter to signal wires and heat up sensor with blowtorch then as you move flame around the voltage reading goes up and down. On a good sensor it changes very quickly and goes up to about 0.9V but on faulty it's slow to respond and max voltage is lower. While I was playing around after a while I noticed that even the faulty sensor started responding better so I heated it well up and for long time and it started working as it should again. It seams it was contaminated but after heating it up contaminants must have burned up and it was working fine. I never put it back in car so don't know if it would have worked well in car or for how long but interesting finding anyway.
Old 18th July 2021, 12:12 PM
Mm interesting find yes ^ Given how much better it runs now, I think both sensors were past their best, but the bank 1 sensor was showing open circuit by the time it came back from the MoT so I guess it failed due to getting properly hot, which it hasn't done so far.
The handbrake took about 2 hours and I was able to do it without removing the prop Pics later.
Old 18th July 2021, 09:55 PM
The handbrake adjustment is buried in here:
Drop the exhaust and support it with the transmission jack
The heat shield studs are mostly broken
Or held in with self-tappers
Tunnel brace off
This heat shield drops down and then the rear one can come out. The plate at the left if this pic also comes out
Then you can see the handbrake adjustment above the propshaft
I was able to get to it over the prop with a long extension. I tightened it until the rear brakes started binding, then backed it off a turn. In total it needed about 4 turns.
With the adjustment done I supported the exhaust so I could lower the lift and check the handbrake applied and released ok from the cabin. It did so I put it back together
I don't have a rivnut tool so I temporarily replaced the heat shields using more self tappers. These will do until the engine comes out, whereupon I will replace them with enclosed rivnuts.
My printed headlight level sensor bracket has been catching on the anti roll bar so I will need to redesign this slightly to make some clearance.
ID:	26732   Click image for larger version
ID:	26733   Click image for larger version
ID:	26734   Click image for larger version
ID:	26735   Click image for larger version
ID:	26736   Click image for larger version
ID:	26737   Click image for larger version
ID:	26738   Click image for larger version
ID:	26739   Click image for larger version
ID:	26740   Click image for larger version
ID:	26742   Click image for larger version
Old 19th July 2021, 07:10 AM
Another fine job MJ
How on earth did someone let the position of the handbrake adjuster pass what passes for a design review!!!
Old 19th July 2021, 07:54 AM
It was a worthy runner up for 'design sadist of the year', along with the bloke who came up with dropping the subframe to get the control arms out, but both were soundly beaten by the door card team
Old 19th July 2021, 09:20 AM
Wish I had those photos of the sensors many years back to show the 'mechanic' when I asked him to replace all four of mine. Told me he couldn't find the pre-cat ones, which may have been a "couldn't be ar**d" attitude. I ended up doing them myself, removing the driver side one from underneath with the front on ramps.
