Is this actually 'a thing' - Never heard of it......
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
It really is. It yields magical fuel consumption and power improvements by lining up all the fuel molecules as they go in to the engine
So what are the plans for your fleet of 9 cars? are most of them just parts cars to feed customer car re storations?
surely keeping 9 D2's going is impossible time wise and probably financially too ![]() |
Dolphin Grey S8 'Lilith' - the best one, never selling her
Big Red - daily driver Barnfind FE - going to a new home when its finished PF S8 - going to a new home asap Murple - going back together eventually & may be a daily T42 - 2.8 FWD, getting a 1.9TDI conversion for 1000 miles range Avus not-FE with black & red - going back to Davey Blueyes eventually 39V Avus FE - gave it's life to save the barn find, shell getting weighed in V7 Black FE - going back together eventually |
Lots of rusty bits have gone off for powdercoating, including the springs which amazingly aren't broken! These have been blasted and will be recoated which will hopefully prevent cracks forming in the first place. They're then baked to make sure there is no moisture left in them before the zinc-rich powder primer is applied.
The powder oven is at 200C by the way - well below the annealing temperature of spring steel so it won't have any effect on the springiness of them ![]() |
So which mythic Lilith is it named after?
Whichever one you fancy
The power steering leak has ruined the rear right subframe bushes. At £50 each, I'd rather not replace eight of them, so I cut up a bad subframe to rescue the bushes from that instead.
The donor subframe was toast anyway Rescued used bushes in nice condition This one has been dissolved by the power steering oil The dirty bits are where the rubber was split Someone has damaged the access holes for the rear arm mount Some heat from the mapp torch and a little percussive maintenance and they're back in shape This is one of the reasons for the catastrophic oil leaks - the last time the timing belt was done the special o-rings on all the cam end-caps weren't replaced but just smeared with silicone. There are two sizes of these, and alas this small one is NLA so I'll be experimenting with traditional round-section o-rings to seal these up again. Luckily the larger ones are still available from Tradition. Cam locking tools kindly on loan from Prestige ![]() The oil leaks have contributed to the oil cooler pipe being completely destroyed Its as bad down on the block as Big Red was Cleans up ok though. |
