Old 18th August 2021, 08:25 PM
How to fit a brake block to a PF...
Don't need this for a start - its not doing anything and in the way
The ESP return hose is also in the way. Interestingly that goes from the front of the reservoir straight to the rear chamber which was unexpected. Of course having just filled it with fresh fluid I now have to remove most of it Never mind. Its not expensive.
Remove this connection and the one from the hardline on the other side, being careful not to spill any fluid on the nice clean paint!
FL hose on the top, PF on the bottom. The PF hose is just a bit of plain clutch hose, whereas the FL is deliberately moulded to clear all the stuff in the way, such as the brace.
With the hose and superfluous bracket removed there's room for the brace hardware
Test fit with a brake block
Clamp in place to mark the holes
This is the rivnut tool. It'll set up to M12 without a problem.
Five of six rivnuts in place, but the last one is blocked by the bonnet switch. This bracket is to the far left of the frame on the FL, clearly moved so they could get tool access to insert the rivnut.
This one will need to be set the old-school way. The nut in the middle compresses the rivnut against the larger nut at the left, allowing it to be set with spanners in a much smaller space than the big tool needs
Hold the bolt and the large nut with two spanners while tightening the small nut with the 3rd spanner
Done
ESP hose back on
Proper clearance now
Bolted in place with the brake block
Brackets left in place but the bar is removed as it needs to be out to replace the wiring harness when the engine goes back in. The inner bolt for the bar is still a little tight on the bonnet switch, but its not like the bar comes out very often so it won't be a problem
I've never seen this done before, and these parts are only listed for the FL so this might be the first PF with an upper brace and brake block?
ID:	26967   Click image for larger version
ID:	26968   Click image for larger version
ID:	26969   Click image for larger version
ID:	26970   Click image for larger version
ID:	26971   Click image for larger version
ID:	26973   Click image for larger version
ID:	26974   Click image for larger version
ID:	26975   Click image for larger version
ID:	26976   Click image for larger version
ID:	26978   Click image for larger version
ID:	26979   Click image for larger version
ID:	26980   Click image for larger version
ID:	26981   Click image for larger version
ID:	26982   Click image for larger version
ID:	26983   Click image for larger version
ID:	26984   Click image for larger version
ID:	26985   Click image for larger version
Old 19th August 2021, 10:38 AM
Done
More attention to detail. Most mechanics would just bend the switch bracket out of the way to use the rivnut tool. As for the spanners, are you tri-dextrous?
Old 19th August 2021, 11:12 AM
It didn't even occur to me to bend the bracket
If you get the orientation of the bolt and larger nut right then both those spanners can be held with one hand while tightening the smaller nut with the other
Old 20th August 2021, 08:06 PM
More rivnuts This is what remains of the screw holding the airbox trim
grind the stump down so I can get a drill on it
Drill out the bolt and the top bit of the rivnut
Remove the rivnut
Ta dah!
One in the front of the wing for the front bit of the same trim
(yes, I did change the bolt for a not-rusty one )
and one over by the header tank for that cover
ID:	27001   Click image for larger version
ID:	27002   Click image for larger version
ID:	27003   Click image for larger version
ID:	27004   Click image for larger version
ID:	27005   Click image for larger version
ID:	27006   Click image for larger version
Old 21st August 2021, 08:53 PM
Looks amazing! I wish I had your patience to clean mine, its a bit grimy inside.
What do you use for cleaning grease and grime off the painted bits?
Would brake cleaner start attacking the paint?
Old 21st August 2021, 09:29 PM
Chlorinated brake cleaner probably would. I use a naptha-based brake & clutch cleaner from TPS which is very mild but which cuts through oil and grease very well indeed, although ironically it doesn't dissolve brake fluid Its much easier on PF and FL1 though as they are lacquered in the engine bay and so quite robust. The FL2s aren't lacquered so you have to be very careful not to dissolve the paint! On those I use Gtechniq W7 tar remover as that is quite benign and remarkably powerful. I also have a product called 'Dirt Juice' bike cleaner from my neighbours which is also quite a mild solvent but in an aerosol so it has dirt-blasting power if needed.
Once the oil is gone I use Gtechniq W5 APC most of the time, in varying concentration depending on the level of grime. In this case, being the worst I've encountered so far, the W5 was mildly supercharged with 10% Autosmart G101 which is an extremely powerful alkaline APC - basically a trade version of the Elbow Grease product discussed in other threads. I'd be disinclined to put G101 anywhere near an FL2 engine bay though. Beware toluene-based tar remover as well as that also dissolves the unlacquered paint.
Once it's all clean-ish with no more grit or chunks I'll use a waterless wash or quick detailer to tidy up any smudges, and then a sealant to finish off.
Old 22nd August 2021, 10:40 AM
Thanks
I am going to stick to the ones you recommended. The Halfords brake cleaner I have seems to attack the paint/lacquer. I think mine is FL1? Autumn 2001 build date.
Will the naptha brake cleaner from TPS also work on the engine block?
I'll have a lot of cleaning to do there.
