Old 30th August 2021, 01:11 PM
quattronutter quattronutter is offline
It sure does! That part has correct colour for aerial cables and dab cables but in one unit
Old 30th August 2021, 05:04 PM
What does your existing aerial look like, is it on the left or right side? Are you able to post a photograph?
As others have fitted in the past, if you want TV and DAB in one unit you need 4E0 035 225 AK; or 4E0 035 225 AL. The difference between the two depend upon the glass, either heat insulated (AK) or laminated (AL).
4E0 035 225 G refers to an aerial for TV and the webasto heater.
But get a photo posted so we know your existing aerials, you maybe able to keep your DAB and add another just for the TV connections.
I've labelled an aerial so you know what connections are what service.
Matt
Old 31st August 2021, 08:09 AM
Current aerial is 4E0 035 225 AH i have picked up a 4E0035225G for 15 quid to try,failing that il get the one you mentioned if previous have used with success
Old 31st August 2021, 09:39 AM
Great explanatory photo matty which might help someone when trying to diagnose a problem, and glad someone could explain the differences.
Old 31st August 2021, 10:08 AM
I will confirm which aerials work once i have swapped everything over,just need 2 mins to fit new interior rse fridge and alcantara roof
Old 31st August 2021, 10:40 AM
homer simpson's Avatar
Interesting! Pics afterwards would be great, I'll wait 2 mins no probs
May pick your brains for the RSE at some point or a write up would be even better
Old 4th September 2021, 03:18 PM
Just went to plug in the green fbas cable from tuner to mmi ecu and its a 4E0 035 729 Without the input! Not a straightforward swap to a 4E0 035 729A i dont think
