Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 11th December 2021, 01:28 PM
Ronin Ronin is offline
You just have to undo the bolt, the nut is part of the alternator casing and is permanently attached to it
Old 11th December 2021, 01:46 PM
Now that makes sense. Cheers Ronin.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 18th December 2021, 06:08 PM
OK. I took out the Alternator today:
Quick look at the junction box - all seems good.
wiggled it so the back end dropped out below.
Removed two bolts from a 'brace' or strap consisting of thin steel which gave enough downward movement to remove the alternator from below. No removal of coolant hoses or fan body to facilitate this
The alternator.
The regulator / rectifier?
I found that there was some 'clutch' when spinning the alternator clockwise, but looking at the overall condition I am thinking it wise to source a new replacement
ID:	27499   Click image for larger version
Name:	Alternator Above.jpg
ID:	27500   Click image for larger version
Name:	Alternator Below.jpg
ID:	27501   Click image for larger version
ID:	27502   Click image for larger version
Paul
Gosport UK
Honda Jazz
Old 18th December 2021, 07:06 PM
Good work.
BTW I have just ordered that coolant hose which runs too close to the AC compressor, its gonna be £20 inc. postage if you still want it. I'll have it by late january
Old 19th December 2021, 10:24 AM
Good work.
Yep. I will take one. Just PM'd you
Paul
Gosport UK
Honda Jazz
Old 22nd January 2022, 02:21 PM
It has been a while as have replaced all the front suspension top/bottom arms, links etc with Meyle/Lemforder components, looks shiny (i even repainted the shocks )
Ok, I had the alternator repaired. Back in, reversal of removal and no issue.
Back on the ground and ready to fire up. Turns over no issue at all, trying to 'catch' but not getting anywhere. Earlier in this thread it was stated the fuel pump is at risk of pooping itself. I am beginning to think that may be the case but what am I really looking / listening for? I may not of been hearing the fuel pump, it may of been the HVAC system as sat in the car when trying to start it. How I can check for definitive proof, or is it a given that this is the next item to replace when the the alternator goes FUBAR?
I did crack open the feed to the fuel rail and that was squirting fuel under pressure but this may be residual?
Paul
Gosport UK
Honda Jazz
Old 22nd January 2022, 04:01 PM
I don't know if this has been mentioned elsewhere in the thread, but if you stand outside the car and turn the ignition on (don't start), you should hear the fuel pump prime itself for several seconds. Of course, that doesn't guarantee that the pump is working 100%.
