Old 11th January 2022, 10:29 AM
homer simpson's Avatar
The lock/unlock feature is completely different to starting the car. The car starts, so the authorization works. Try putting the key near the steering column and see if the start button works.
Ideally you want a scanner on the car to see what codes it is throwing up. Also check that the passenger footwells are dry
