Old 4th February 2022, 10:29 PM
AlHeart AlHeart is offline
I'm looking for a place to power a dashcam without having to bring a wire down the a-pillar. I thought about using the circuit for the On Star which I have since disconnected at the fuse panel because the green LED was very annoying when driving at night.
I've managed to remove the light covers and fascia. However on page two of the guide above, it states,
Roof electronics control unit -J528- must be reencoded after renewing.
Does this mean I have to use VCDS to reencode the roof electronics control unit if I remove the rest of the electronics?
I do not have VCDS so I don't want to go any further if I need to.
Thanks!
Old 5th February 2022, 09:05 AM
If you mean when you just physically remove the console from the car, then no, you don't need to code it. That would only be necessary if you were to replace it with another unit, as there are other features of the car that this console needs to be 'aware' of.
In terms of finding power, check out the following thread by Delboy:
http://forum.a8parts.co.uk/showthread.php?t=8377
Old 5th February 2022, 03:05 PM
That's awesome thanks!
That thread by Delboy is great too!
