11th March 2022, 02:31 PM
Originally Posted by Goran
With the vac hose to brake booster disconnected car moves a bit more freely, but as soon as brake discs warm up it locks up again, even going at 15~20mph.
Sounds like you may have read this thread (which MJ participated in), as that was their solution:
https://www.audiworld.com/forums/a8-...rners-2912722/
Since it just went through the MOT, that would eliminate air in the system or a leak, which just leaves the brake booster and master cylinder. Do you have access to VCDS (or similar) to check the ABS for errors?
