Old 20th May 2022, 12:58 PM
The big rectangular connector only has about 3 wires in it iirc - can't remember if they go to the tv tuner or phone interface. I think its a kind of auxiliary interface which is probably redundant with the RNS-e.
The CD changer comes in on one of the three small square connectors which are locked together -yellow, blue or green.
Old 20th May 2022, 05:26 PM
The entirety of the CD changer wiring is in one block of that, including the power supply. I've hacked into it a while back and can confirm that.
The other two parts of the 3-colour connector are for telephone and line out (for Bose?).
The round DIN-style connector mentioned above is for video INPUT only. The commands to the TV tuner go by another route, probably the big connector (via Canbus?)?
The big connector has the Canbus (2 wires) and RFLS (reverse, one wire) definitely, not sure anything else of importance.
Edit: I think the NF+ and NF- pins are for telephone audio (input to RNS), not sure about DFA_R and DFA_L ...... (Though one post I found online suggested they were wheel speed sensors input to the Satnav ) I guess someone prepared to work through a wiring diagram could figure that out!
Old 20th May 2022, 08:51 PM
The entirety of the CD changer wiring is in one block of that, including the not sure about DFA_R and DFA_L ...... (Though one post I found online suggested they were wheel speed sensors input to the Satnav ) I guess someone prepared to work through a wiring diagram could figure that out!
OK so that was me! I happen to have a wiring diagram (Current Flow) PDF on my PC.
A search for DFA produced a pair of direct connections (L and R) between the RNS (J402) and the "ABS with EDL control unit" J104.
So if your car has that wiring it's presumably input from the ABS to the SatNav. Whether RNS-E needs it or not is another question....
Edit: As Ian (IT) noted in his thread (linked to by Sean) the RNS-E Canbus setup is different to the RNS-D, that may be why there's a whole unused connector!
Old 9th June 2022, 02:17 PM
Ronin Ronin is offline
why not stick an android in and get the car's infotainment up to date?
Old 10th June 2022, 08:42 AM
The main reason is cost. Second reason is that I just want something to play music and give me sat nav whenever I need either of them.
Old 10th June 2022, 03:14 PM
The big black connector, from memory, has few wires in it. I seem to recall it has a gala/wheel pulse input (from abs) and reverse line signal (so the car knows if the pulse is going forwards or backwards).
There was a second 'gala' input on the 8 way power block, which was also a speed input.
One was used for the GPS positioning, and one was used only for telling the unit you were moving, and to turn the TV off if in motion. A common hack was to put that on a switch so tv in motion would work. Sat nav was unaffected.
Likewise, losing a reverse signal isn't the end of the world, unless you spend a lot of time driving backwards underground, but I also suspect that signal would be mirrored over canbus which the RNS-E would likely read natively from the cluster.
So, yes, i dont doubt that black connector is happily surplus.
On the Cd changer, vw/seat/skoda/RNS-E Audi all used a square connector for the CD changer. When I did my retrofit, I swapped the CD changer cable for one of those and it plugged straight in.
I guess, with the RNE-E having SD cards, the need to CD is somewhat reduced so not something people worry about plugging in.
Old 10th June 2022, 05:02 PM
I'm pretty sure that's the one that you break for TV-in-motion and it doesn't do anything else.
I'm certain My Kufatec TVIM lead loops in there via an adapter.
Though I'm hoping (fingers crossed) that wiring can be simplified and the adapter dispensed with while my S8 is down with MJ.
(The DVB-T tuner I'm also giving up on so it's only the reversing camera that needs it. Surprising how often I reverse faster than 5mph though.... )
Old 10th June 2022, 03:31 PM
An Android head unit surely is cheaper than the elusive C5 RNS-e? The Icebox one which looks similar is £320 iirc. Nice condition RNS-e units seem to be 300-400 plus all the adapters and expensive 4GB non-HC SD cards.
I'd consider an RNS-e a more expensive option where you are prepared to pay for the OEM integration and user interface. The Android unit is a pain with Bose because of the odd characteristics of the amp, but non-Bose should be simple enough. I'll grant it does get more expensive and complicated when you have to change the amp though.
