Old 16th August 2022, 08:14 PM
GarethS8 GarethS8 is offline
I'm scared now lol, as I'm gonna attempt to change my door card on my d2 in a couple of week.
Plus Way to Many others
Old 16th August 2022, 08:18 PM
Just work up to it gently; First I'd start with changing the F125 as a "beginners challenge".
Old 16th August 2022, 08:46 PM
Ronin Ronin is offline
Removing and replacing door cards is easy.
D2 has a more complicated system than a ****ty mass produced ford that presses the door card against the door frame harder to aid with sound proofing(and also why there is a foam seal going all around it except for the top)
Old 16th August 2022, 08:56 PM
Indeed, I'm always surprised when I travel in my S8 with passengers and realise we're chatting to each other normally with minimal background noise in almost all road conditions and speeds.
In any other car you'd give up talking and just and turn the radio on loud. In my S8 the radio/music usually off unless there's something I particularly want to listen to. Apart from the V8....
Old 17th August 2022, 06:09 PM
And indeed I noticed this yesterday evening, driving along a rather poor local B-road in the S8 on a journey that recently has mostly been in the Volvo.
In that I typically drive this particular road at about 40-45mph just for comfort, but I realised I was cruising in the S8 nearer 60, give or take a bit depending on visibility ......
Old 16th August 2022, 09:16 PM
If it's one of the rear ones, check out the following thread:
http://forum.a8parts.co.uk/showthread.php?p=85205
Removal of the front door cards will be quite similar.
NB: Be very careful when disconnecting the bowden cable from the door handle. Check out the 14th photo in the above thread, which shows a closeup of the end of the bowden cable, and is highlighted with an red ellipse. At the bottom of the ellipse you'll see a small greyish metal clip, and at the top of the ellipse you'll just about notice a small black piece of plastic at the end of the cable. Both of these parts are essential and are very easy to drop or misplace.
Old 17th August 2022, 09:02 AM
Sean,
You are a stickler for the finer points.
Well done and thank from everyone for your diligence.
All part of you extensive repair manual production experience of course.
