Old 4th November 2022, 09:27 PM
Wow. I've never seen one do that before. Its like one pixel became infected and spread to the others in a fractal pattern. Very odd.
I didn't know BBA could do D2 LCDs - thats quite handy.
They could do the job but it is unlikely that they can get hold of a new replacement display for D2. I replaced mine on C5 A6, was simple enough and plenty aftermarket available as the same one is used on number of different Audis. But D2 display is different and I don't know if it's used in any other cars, so probably nobody has invested in making replacement considering the low volume niche market.
And if they need to use 2nd hand display from another cluster it's probably cheaper and less risky to make the donor cluster work in your car rather than swapping the displays
