For Sale and Wanted - Cars For the sale of whole cars, Audi or not, working or not. No cross links to other peoples cars please - Use Spotted online instead |
The only difference is that one has the cut out for the key barrel and the others don't. Not really worth buying a second hand one either as they will be worn (common issue)
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
these part numbers are for an A8
i need Q7 ones as this thread is about my Q7 not A8
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
That being the case, the Q7 options are more varied from a quick look, so need some clarification on exactly what is specced on the Q7. Apart from the keyless part, there is also mention of a 'chrome package'. If you have the build sticker, here's what I've found. All the handles are the same, but there are 16 variants of them: QJ0 - without chrome package QJ1 - chrome package
i think ive narrowed it down to this one as i have keyless and chrome strip
i will look at the build sticker thou laters https://www.ebay.co.uk/itm/115450503181
For chrome and keyless, that is indeed the correct one, and a good £70 cheaper than dealer price.
just had another thought
the button doesnt click so im assuming its shot, but could it be something else and would the fault show up on vag-com ?
If it’s a purely mechanical fault with the switch it might not show up. Past experience with my s5 suggests keyless stops working completely if it detects a fault with a door sensor, to prevent unwanted false detection of an unlock command
I’ve replaced all the door sensors on the S5 now - did the first one with an OEM replacement, the others are the cheap versions on eBay and they’ve been faultless since. Am aware the design is v different but might be worth a look?
That would be my assumption as well. Going by the video I posted earlier of the A8 mechanism, and from personal experience of work torches that have surface mount switches in them (three in three years all under warranty, and always the switch stops working - and they weren't used that much), these surface mount switches just don't seem up to the job, and on the door they are susceptible to weather conditions. Since they don't have any sort of latch mechanism, I don't think anything would show up on a scan, and I doubt there is anything in the VCDS measuring blocks where you could test the operation of the switch.
If the switch has failed "closed" then you might get a code. If it has failed "open" then you will probably be able to see it not operating in the measuring blocks.
The next generation of keyless moved away from switches, which brought its own issues! ![]() |
there is definatley a click of a micro swith working perfectly on the other 3 doors..
the 1 in trouble that button seems dead, no click and sunken in slightly.. my A8 did that too..
