Some notes from Ross-Tech, interesting point at the end
![]() 01219 - Side Airbag Igniter; Rear Driver Side (N201) 01219 - Side Airbag Igniter; Rear Driver Side (N201): Resistance too High 01219 - Side Airbag Igniter; Rear Driver Side (N201): Short to positive 01219 - Side Airbag Igniter; Rear Driver Side (N201): Short to ground Possible Symptoms Malfunction Indicator Lamp (MIL) active Possible Causes Wiring/Connectors from/to Side Airbag Igniter, Rear Driver Side (N201) faulty Side Airbag Igniter, Rear Driver Side (N201) faulty Possible Solutions Check Wiring/Connectors from/to Side Airbag Igniter, Rear Driver Side (N201) Check Side Airbag Igniter, Rear Driver Side (N201) faulty Check Measuring Value Blocks (MVB) Special Notes When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information. I can't figure out from the code which one it is, but I suspect the rear seat. I think the curtain airbags may have a different description. I'll check the diagrams tomorrow. If it is the rear seat side bag I have a few spare, although I'm not sure how hard they are to get out. I'll need to have a look at one. |
