Old 5th March 2023, 12:49 PM
Julian Thompson Julian Thompson is offline
Thanks guys I have edited my signature to include the two Audis, thanks for the tip.
So, a question - when I log on to the brake module am I logging on as the car is NOW, and then trying to code what I want it to be once I’m “in” ?
2006 D3 3.0TDI Auto SWB
2008 D3 4.2TDI Auto LWB
Old 5th March 2023, 07:40 PM
Just to let you know the abs unit will not accept any other coding except for how the car came out of the factory, it only accepts one coding value! So you cannot recode it for Brembo M6 AL calipers. If you want ceramics you'll have to have the correct abs unit.
To be honest it's best not to mess with the abs as it's known to register an 'ABS control module defective' fault, even though it functions properly.
Matt
Old 5th March 2023, 08:35 PM
That’s really helpful thanks. I did mess with it tonight before I read your warning so hopefully I haven’t cocked it up. It seems you’re exactly right though. I can log in to the module using the correct code (for my car 05457) as it has the standard little PR-1LG brakes coded, but from there it won’t accept anything in the soft coding section to do with Brembo brakes.
Old 5th March 2023, 09:11 PM
I'm sure it's fine... and stay away from performing any output tests on the abs.
Matt
There is a specific sequence of tasks when coding the ABS, as demonstrated in the following video. Is this the same sequence you followed, bearing in mind that the codes you need will be different, as the video use an A4? If you have, that will at least confirm what matty mentioned:
https://www.youtube.com/watch?v=G7YRiVYrLjo
Old 6th March 2023, 01:13 PM
Thanks guys. The car is fine thankfully. So I had watched the video and that’s how I was attacking it. The problem is that you can’t get the module to accept the login for anything that has ceramic brakes. It accepts the login for two types of steel brakes, but as soon as you code ceramic it doesn’t like it.
I think that it doesn’t like the idea of changing the “car type” from diesel without ceramics to the more general one.
I might buy an S8 module to play with as it would be nice to complete the job comprehensively.
Old 9th March 2023, 11:07 PM
I wonder if I can trouble you guys again for a bit of urgent help? I’ve travelled a long way to collect my ceramic brake kit but on inspection the front drivers disc is damaged. It is part 4E0615302C. I have found a 4E0615302E drivers disc on eBay at a reasonable price. Will this work for me? Thanks, J
Old 10th March 2023, 11:19 AM
Looking up ETKA for 4E0615302C I get the following information. The first thing displayed is a remark stating 'Caution: Mixed installation of brake discs not permitted.' Now I have no idea what exactly that means, whether it means mixing steel with ceramic or mixing different ceramic ones.
The replacement part numbers are 4E0615302F, followed by 4E0615302G and finally 4E0615302H. I couldn't find 4E0615302E anywhere in the entire A8/S8 range or entire Audi range, so searched under dropped parts and found it there, and it shows with it being replaced with F, G and H. In theory is should be fine, as all superseded versions are the same.
