Old 27th March 2023, 08:15 PM
Originally Posted by danyalmakda View Post
How do I get some or where from?
Part number for the large grommet (x2) is 431955465A
Part number for the small grommet is 443955465
Decided to do mine since I had the front end off.
Old 10th April 2023, 10:40 AM
danyalmakda danyalmakda is offline
Have ordered some off eBay
Just waiting to get the energy to re-do this fiddly job
2002 Audi A8 D2 3.7 Quattro AquaBlue
Old 8th June 2023, 04:31 PM
So awhile back I changed the washer fluid pump to a meyle pump and all was fine apart from the grommets which I have ordered - I haven’t used the washers in the last few weeks as not driven much. Was about to change the grommets but realised only the headlight washer is working and not the screen washer
Is that because not enough fluid in? Or the pump?because the grommets are leaking there’s only enough fluid until below?
Just wanted advise before I remove everything so I can do it all at once
Thanks
Old 8th June 2023, 07:42 PM
1. The pump for the windscreen wipers sit lower than the headlight washer pump, so if you're getting water through them, then you should be getting it to the windscreen.
2. When I put mine all back together again, it took a while to get the water to the windscreen. I ran it for about 5 seconds each time, then waited for the wipers to stop, and then repeated the process several times. I was beginning to think that the new pump wasn't working, but it was fine.
3. If the grommets are leaking, you'd see the obvious signs of it below the car.
