Old 19th April 2023, 08:17 AM
sarg sarg is offline
Default Fluid loss front offside corner
Chaps, I'm losing some kind of fluid from the front offside corner.
I imagine this is washer fluid, are there any existing threads / how-tos on to access, diagnose and repair please?
(I did do a search but could not find what I was looking for)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 19th April 2023, 11:58 AM
There were a few comments in this thread that may give you a heads up:
Item 23 onwards:
http://forum.a8parts.co.uk/showthread.php?t=16912
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 19th April 2023, 04:15 PM
Ronin Ronin is offline
Its 2 grommets that you have to replace, forum sponsors sell them. its also a good opportunity take the washer fluid tank out and wash out any junk out of it with a kracher etc.
Old 19th April 2023, 09:59 PM
thank you both
Any theories why it should start leaking while sat in my garage?
Old 3rd May 2023, 01:58 PM
Good news: it's not leaking washer fluid
Bad news: it's coolant
Discussions with our resident Doctor suggest it is probably the oil cooler pipe. I've not had chance to get on the ramps and have a look, so have just ordered the parts (they'll come in useful one day if not now!) and booked in with a local mechanic over the next couple of weeks, hopefully fixed and sorted in time for the annual meet.
My simple brain still cannot understand why it should start leaking being tucked up in a warm(ish) dry garage
Old 3rd May 2023, 02:03 PM
I recall comments that often it's as likely the grommets/washers around the pipe as the (definitely fragile) plastic pipe itself.
Mine had been leaking for ages (years!) before MJ replaced it during its overhaul, though I don't recall how damaged it was.
Old 3rd May 2023, 02:54 PM
Usually the plastic cracks in the o-ring grooves so the pipe comes out in three pieces. The cracks propagate from the sharp edge in the grooves, eventually going all the way round, and then coolant slowly seeps out. It is fully constrained by the engine block and cooler housing so it can't catastrophically fail. It just dribbles in varying degrees.
Old 11th May 2023, 08:45 AM
Replacement pipe has still not turned up, starting to look doubtful the D2 will make the annual meet, the risk of me showing up yet again in a BMW is increasing each day that goes past
Old 11th May 2023, 09:21 AM
Despite it's insignificant size, it's a b*gger of a job to do with the engine in the car, with the increased risk of stripping a couple of the bolt heads, so extreme care needs to be taken.
It might be worth providing the following link to your mechanic so that they have knowledge of what's involved. This was for work on a 4.2 32V engine, with notes at the bottom for the 40V ones. MJ may have a much better insight on any other possible snags along the way:
http://www.audipages.com/Tech_Articl...reinstall.html
Old 11th May 2023, 09:46 AM
If its confirmed to be the oil cooler pipe, I'd take it to the meet and just top up as necessary. It can't fail catastrophically and as Andrew noted, they can run for many years with the pipe cracked with no adverse effect than marking their territory overnight
The only activity that failure would stop me doing is taking it on a track
