Old 22nd May 2023, 03:01 PM
sarg sarg is offline
Have you managed to remove the pipe, and if so, what size hole are we talking about?
I've got the airbox and gubbins out, got pipe #9 off, had a feel around bottom pipe #11 and can feel the hole, and could see some coolant dripping straight through it before it reaches the opening - need to get underneath again, but I'd say hole is about 5-6mm - more will likely be revealed once I get the pipe #11 off
I removed the clip at the front, holding #9 on to #11, with regular pliers, but I'm not entirely convinced my clip here is OEM, it looks a little different to the diagrams. EDIT: looks the same as the ebay items so maybe is OEM
The MAF connection I sorted, was just being a noob, realised the plug unclips rather than having to unscrew the socket.
Are you saying that once the rear clip is loosened, a bit of force and wiggling should bring the metal pipe out?
As for the meet, it's only about 10 days away, and I am dependent on parts arriving, which I have not yet sourced all of, so with the best of intentions, if it's still in bits awaiting parts, then it's still in bits - the clips for example, are about 4 weeks' lead time - I might be able to reuse existing one, or replace with jubilee clips, will try that before ordering them
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 22nd May 2023, 03:11 PM
That was about the size of mine, plus a smaller one under the rubber pipe #9.
MJ was able to offer me a replacement pipe at short notice. Not sure if she'll have any available.
I ordered the clips from eBay and the tools from Amazon, and with living in NI, it takes several days longer than on the mainland.
Old 22nd May 2023, 03:20 PM
MJ has offered a replacement on basis I can provide a decent condition (i.e. no holes!) item from abroad to get re-powder coated, so am onto that, waiting on MJ to confirm she can post me one
And no response yet from Prestige about rubber pipe #9 - do you have a part number, can look on ebay? Mine 'looks' ok, but concerned the rubber might have got a bit hard and contributed to the leak which contributed to the rotting, so while I'm in there might as well replace if I can get a new spare
Old 22nd May 2023, 03:35 PM
Part number is 4D0121101T. I didn't replace mine as it looked fine, but that's only my opinion.
Both the following have them listed, but both in Germany, so obvious delays in getting them here:
Audi Tradition (issues with sending to the UK, but Dean (Spanker) offers a service, which I had to avail of: https://shops.audi.com/en_GB/web/tra...erm=4D0121101T
Original Teilemarket.de (have also used these people and very good - just need to check shipping costs and charges for 'legacy products' - I think they might source stuff from Audi Tradition, but it's just a thought): https://originalteilemarkt.de/schlauch-3105481
Only other one I can find is a used one in the US on eBay.
Old 22nd May 2023, 03:53 PM
Thanks Sean, if Prestige can supply for anything close to the Tradition price, then its worth it IMO, will chase them by phone tomorrow
Old 22nd May 2023, 07:06 PM
Spanker's Avatar
Spanker Spanker is offline
Hi Sarg,
If you've exhausted your UK options and you think I may be able to assist then just drop me a PM.
Dean
Old 24th May 2023, 04:28 PM
I think these cars are meant to haunt us, even when we do pay attention to them. Since my 182 test drive at the start of May, I'm been using the car for a few short runs to the shops. Last week I was helping my brother with renovating a house and so that got the car out for a series of 16 mile round trips.
This week, with my niece and partner over from Germany, I took them and her father for a 170 mile trip around parts of Donegal. Parking sensors and lights on dash.
Now, I can't remember if I mentioned it, but after getting the car roadworthy again, and before the MOT, I was quite vigorous with the pressure washer, and only discovered about a week later that one of the sunroof drains was blocked and the passenger footwell was wet. Well, primarily the rubber backed mats were saturated. I didn't realise the one to by the door and the main carpet under the seat also had rubber backing, so only dealt with the main one. I thought it was all dried out... until today after I scanned the car.
Main issues were parking sensors, alarm activation and lateral acceleration sensor. Can understand the last one as I think that is under the passenger seat, but alarm activation was caused by rear drivers side door. Strangely enough, my alarm (well, flashing lights) went off around 11:00pm, about an hour after I got home, and it seems one of the rear sensors has just packed up and disabled the lot of them.
Can't work on them as part two of the tour continues tomorrow, of around 180 miles. I can then investigate them afterwards.
