Have posted a response in my 'coolant loss' thread, and MJ has also mentioned about the relevant tool to access the rear clip.
Just to repeat here for future reference to this thread, part number for the clips is N90655801. In terms of awkwardness and difficulty, the rear clip will only be removed with the tool MJ provided a photo of, and from above. The two bolts holding the pipe are a case of finding them with your fingers. I used a allen head bit along with a stumpy ratchet spanner to remove them. Removing the airbox gives a little bit of room, but not much. I didn't even touch pipe #3 at all as it looked fine. EDIT: Once pipe #9 is disconnected, removing the metal pipe was just a case of gentle up and down movement from the front (like using a ratchet) and easing it off pipe #3.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 22nd May 2023 at 02:44 PM. |
Long reaching tool thingy and some G12 coolant ordered, next challenge will be getting this pipe off, wish me luck again
Had another poke around this evening, lokos like my pipe actually has multipe small holes, see image - I've stuffed the pipe with blue paper towels, you can see the blue through the holes.
I've got the right allen key bit for the two bolts, but I cannot work out at all how I am going to get to back of the pipe - I could see from beneath with a torch, but could not get hand to it, and can't see it at all from the top. Am hoping when I remove the air intake in 2nd image that a) I'll get better access to the 2nd bolt holding the pipe on and b) it might help me see the back of the pipe from above. Any tips / advice please? Should have called this thread WISG (What's In Sarg's Garage) ![]()
2002 Mark's D2 S8 FE 2020 BMW M340d xDrive (Anely's daily driver) 2000 FL D2 4.2 QS - SOLD 2011 ![]() Last edited by sarg; 22nd May 2023 at 10:33 PM. |
About to leave on being a tour guide for the day, so will be tonight before I can check on progress.
![]() Going to look for some safety gloves first to protect my knuckles ![]()
2002 Mark's D2 S8 FE 2020 BMW M340d xDrive (Anely's daily driver) 2000 FL D2 4.2 QS - SOLD 2011 ![]() Last edited by sarg; 23rd May 2023 at 08:09 AM. |
I now have all the (known) parts I need, and the tool, work restarts tomorrow morning, stand by for much head scratching and appeals for help and advice on here
For the car, just the pipe, two clips and G12. 'Long reaching tool thingy' and some method of getting the allen bit into place and turning it. Other other requirements are likely to be a swear box and some sticky plasters, depending on big your hands are.
I have all listed, including goalkeepr sized hands, about the relative size of this smilie... ![]() |
Sean's going to have to be on point for this one as I'm hoping to be doing some laps of the nurburgring
#30
Would offer to do it no problem, but a bit far from Londonderry to West Northamptonshire... and there's quite a bit of water in between... unless you meant at the meet!
