Old 30th May 2023, 06:10 PM
Is there a guide to removing the belts anywhere?
Ive bought 2 front belts from A8 Parts and taken them to an auto-trimmers to be re-webbed. But it’d be helpful to know how to remove the existing belts when the ‘new’ ones come back.
Old 30th May 2023, 08:58 PM
Ronin Ronin is offline
There is a service manual pdf on forums with the other service manuals
http://forum.a8parts.co.uk/showthread.php?t=9345
Old 31st May 2023, 06:09 AM
Thank you
Old 31st May 2023, 08:53 AM
Start from page 69 of the following PDF:
Service Manual General Body Assembly Interior (Repair groups 68 69 70 72 74).pdf
I haven't read through it, but (amongst other things) you need to remove the lower B-pillar trim, and in order to do that, you need to remove the front lower door trim and partly remove the rear lower door trim. That gives access to two screws with black plugs (for want of a better term) to be removed. You then need to disconnect the light source to the rear air vent in the B-pillar. I've marked where it is cable tied to. There is still the top section of trim to be removed as well.
BTW This is me trying to get rid of the swimming pool in the rear passenger footwell, so only rough photos.
I'd be interested to hear how much they cost as mine is so much worn, as disgustingly dirty. That's what happens when you wear working clothes and then proceed to drive the car with them on.
Name:	IMG_20230531_094706_712 (Medium).jpg
ID:	29595   Click image for larger version
Name:	IMG_20230531_094725_850 (Medium).jpg
