Old 26th September 2023, 02:45 PM
Mossyboy1978 Mossyboy1978 is offline
So now I am really confused.
Autodoc sent me two new coolant reservoirs by accident instead of one. Hooray!
Installed first one and the same warning comes on about 10 seconds after ignition. Considered it could be a dodgy sensor in the tank and so installed second one. SAME THING happens!
Checked sensor plug wiring and all connected up properly inside the connector. No rust etc. All tidy.
Checked sensor plugged into connector the correct way and it is.
What on earth could be causing this to keep flagging an alert if it isnt the connector or the sensor in the tank??
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
