Old 20th December 2023, 04:06 PM
As of now, Dolph is currently withdrawn from sale until I’ve had more seat time.
All good news, and hopefully a full reprieve on what could have been its potential demise.
Old 29th December 2023, 03:55 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Nearly 600 miles completed over the Christmas period without issue
Once it ticks over to 136k that will be just shy of 1000 miles completed and then I will make a final decision. Im 99% certain I will still sell Dolph, but it will be a case of trying to work out what to advertise her for taking all the niggles into consideration.
In other news I just bought a new to me 2016 Audi S5 Black Edition. Supercharged goodness
Old 6th January 2024, 10:12 PM
RICKY D's Avatar
Well, that's 136k miles and some change now completed
In the other thread MJ was right after all - Thank you!
It may well be the sensor then - they can be pretty erratic when they are failing, and get worse when they're hot. They fail sufficiently often that I keep a bunch of them in stock and change them as a matter of course when I take the engine out. They are only £6 or so, although they are a bit of a bugger to change. I'd try that before abandoning it.
Based on the opinion of a garage I've been using for a while I very nearly scrapped/broke this car
My main garage is a friend of mine and he was the one who eventually convinced me to try the NEW pressure switch (after MJ advised it as well ). He normally does the easier stuff such as brakes, oil & filter, service, etc. and the other garage normally does the more technical, labour intensive stuff.
The problem is the owners back gave out in the summer and he's not been in as often leaving his head mechanic to manage most jobs. He was the one who said the engine is scrap and the car is pretty much scrap too. I've since spoken to the owner because I was told it was the oil filter housing debris, failing that starved the engine of oil. He said it was purely a coincident, but the housing failing was not that actually that bad . It had only partially collapsed and there was some debris in the pan, but nothing the oil pump, gauze and filter couldn't handle. Failed timing chain guide pieces he's seen in sumps have been bigger. He was surprised the other mechanic dismissed my suggestion about changing the pressure switch considering the cost!!! At least it's done now for the new owner (if it sells!)
It's left me feeling quite sad actually. I'm getting rid of a car I love because I cannot find a garage good enough to work on these magnificent beasts. I've had a D2 of some form for 10 years now so I know how they're meant to feel when driving but trying to convince a garage to investigate stuff is getting increasingly tiresome. At least I will still have my Green Beast for a little while longer...
Old 10th January 2024, 06:21 PM
donp38 donp38 is offline
What a result!
Fab. Well done MJ.
Should have been a straightforward diagnostics... plenty of independents...time to get a new one I think?
