Old 6th February 2024, 02:05 PM
CaifanSC CaifanSC is offline
I think that may be the one. I pulled up the PN, and two sizes came up. Could anyone confirm which size is correct? I see M18x1.5 or M12x1.5.
Audi V8 Quattro Original 5speed - Black/Black
Audi S8 - Avus/Oxblood
Audi S8 - Cashmere/Twist
BMW 850i - Red 6speed
BMW 850Csi - Red 6speed
Ford Thunderbird x 3 Supercharged & 5speeds
Mustang convertible
Range Rover Autobiography - BRG/English Tan
Old 6th February 2024, 02:17 PM
There is no size given for the D2 one, but the exact same part number used in the D3 has a size of M18x1.5. Also on the D3 parts list, it lists a separate seal ring, part number N0138321, size 18x22.
Old 11th February 2024, 11:39 PM
Thanks for the info, steamship. I found pictures of the N0138321 seal ring, and it seems to be a metal crush washer. While the diagram you posted and other pictures I've found show a flat-ish rubber O ring. I think I'm going to order the smaller M12 bolt/seal and report back.
Mustang convertible
Old 12th February 2024, 07:14 AM
The attached image is from the official parts catalogue for both the D2 and D3, and it does 'appear' like its a flat-ish o-ring. However, considering where its used, the colour might be misleading. Why not order both, so long as you can return the unused one.
Name:	Screenshot 2024-02-12 082357.png
