Old 2nd March 2024, 10:54 AM
zed_thirteen's Avatar
zed_thirteen zed_thirteen is offline
yes, I did mean lift.
I cant really describe the rate of acceleration. .If I accelerate quite quickly (not maximum warp!) then the lift option on the MMI becomes disabled. It tends to stay like this until I brake quite sharply (gentle braking doesn't seem to enable it) I think it might cruise for hours in the disabled state until fairly sharp braking occurs again?
I will check out the link you provided though - thank you
2003 A8 D3 V8 3.7l petrol - retro fit audi handsfree bluetooth, DAB Radio, Digital TV, fully populated aerial amp, metal capped window and handbrake switches, brushed metal dash trim and switches, graphic parking sensor display
Old 2nd March 2024, 12:11 PM
Would that be like doing a 0-60 run type acceleration? You mentioned the level sensors, and that might be the issue, although I would have thought that if there was issues with one of them regarding readings, it might flag up one of the suspension lights.
I can't think how mechanically a level sensor can get 'stuck', if it still attached properly, so maybe a dodgy connection due to water ingress, or water ingress into the actual electronics.
Do you have VCDS or other diagnostics tool that you could use? I suspect there's bound to be measuring blocks in module 34 (Level Control) that you could check for the four sensors, to see if they are all within the same tolerance. In theory, you should also be able to check these values whilst cycling through the various suspension settings. Then again, they might all show up as fine whilst stationary. VCDS does allow you to log data, so maybe you could start logging the four sensors, go for a normal drive, and try to replicate the issue, and then check the results.
Tags
air suspension, automatic, dynamic, lift
