Old 7th May 2024, 04:17 PM
Opened it up, batteries not good but PCB looks like it's probably OK.
Batteries are of a geometry that's NLA, though you could probably bodge a pair of 3-cell Varta ones to fit by making your own tabs. The battery is a 2*3.6v 140mAh Ni-Mh unit with 8 (yes eight!) soldered mounting pins, a bit weird!
It's not obvious if the batteries supply just a 7.2v feed or if an intermediate 3.6v is also used.
If I do try to repair it I'll take a 3-core lead (0, 3.6v, 7.2v) through the casing and fix suitable battery packs externally. 3.6v Ni-Mh are readily available.
