Old 21st May 2024, 10:45 AM
sarg sarg is offline
Another couple of days lost to an already tight deadline.
fingers crossed for you
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 26th May 2024, 08:29 AM
UPDATE - ♪ Back on the Road Again ♪
Brakes - Something I forgot to mention in the previous post was about the callipers, which I should have spotted as soon as I opened the box. They arrived without the carriers on them, despite the photos showing otherwise. That meant more work pulling the old ones apart, and cleaning the carriers before transplanting them over.
Anyway, this is how much of the spring that broke off (cut again with an angle grinder to get it out of the way):
This is the before and after solution, and yes, those are genuine old 'new' stock shock absorbers. Bought them in 2017, and even back then had difficulties getting them shipped across to NI. Ended up sending them to my brother who was still living in England at the time, and he brought them over when he came fishing.
And this is the final result, times 2:
I also bought two new pinch bolts thinking I'll replace them while I'm at it, since they're a known cause of heartache, even though I don't have to touch them, and true to form, one was seized solid. Ironically, it was the drivers side, the same side that I had to replace the entire suspension strut of (thankfully, A8parts came to the rescue on that)... because the mechanic couldn't get the pinch bolt out of the original. That was in April 2017, and true to his form, he hammered it in that tight, it's going to be another nightmare to work on.
There's still the MOT to get done, and even though mine 'expired' a week ago, I'm still able to drive it on NI roads because of the backlog here. My MOT date is at the start of July, so tomorrow I have to phone them and ask for an emergency appointment because I'm going across to the mainland. I still need to check around the rest of the car to make sure none of the little things are likely to fail it, and also get it washed top and bottom.
When I was at the physio during the week, we were talking cars, and he said he just booked his MOT, and the date he got was in October!
Name:	IMG_20240518_101602_116 (Medium).jpg
ID:	30253   Click image for larger version
Name:	IMG_20240517_171019_259 (Medium).jpg
ID:	30254   Click image for larger version
Name:	IMG_20240518_185955_335 (Medium).jpg
ID:	30255   Click image for larger version
Name:	IMG_20240524_121614_817 (Medium).jpg
Old 26th May 2024, 10:22 PM
Old 27th May 2024, 11:21 AM
Good luck with the MOT Sean and hopefully you'll be able to make the meet
Old 27th May 2024, 06:27 PM
Hope so. I phoned them at 9:00am this morning only to discover it's a bank holiday, so will try again tomorrow. Hoping to get it done and passed this week so I can get a good long test drive done before heading across. A 400+ mile drive to the meet ain't my idea of doing a test drive.
Old 28th May 2024, 08:11 AM
RANT - and I'm keeping this as polite as I can manage!
The DVA in NI is £$%^&* disgrace.
I phoned them first thing, and spent 10 minutes on hold. I'm told they issue 'emergency' appointments based on the same data that the drivers have access to. Bearing in mind that today is 28th May, these are the 'earliest' appointment dates available at all the NI sites:
I literally have to sit here on the laptop with their page open, refresh it, scan for a suitable appointment, and if there are none, refresh the page and start again. I get 20 minutes of this and then the session is terminated. I then have to start at the first screen and repeat the whole process.
Even if you do find a suitable date, by the time you've clicked on the centre name, the appointment has gone! She even said that some people are going across to Scotland to get MOTs done. Yeah, no problem, £300 plus fuel costs to get a MOT.
Name:	Screenshot 2024-05-28 091915.png
ID:	30261   Click image for larger version
Name:	Screenshot 2024-05-28 091924.png
Old 28th May 2024, 08:34 AM
Can you take the risk and book one over here around the meet weekend?
Old 28th May 2024, 08:39 AM
Want me to book you in at our local MOT station, I guess you can legitimately drive here to a pre-booked appointment?
