Old 30th June 2010, 01:07 PM
ulfilias ulfilias is offline
Well i cleared the codes and gave it a blatt down the road and back and they haven't shown up again. So i'll run arround a bit and see what happens
The values are slightly larger and seem more consistant.
@AVP are those figues for an S8 4.2 D2 AVP engine ???
Old 30th June 2010, 05:01 PM
Ok. some new codes. we are making progress !
17831 - Secondary Air Injection System: Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System: Bank 2: Insufficient Flow
P1411 - 35-00 - -
Old 30th June 2010, 07:58 PM
17831/P1423/005155 - Secondary Air Injection System; Bank 1: Insufficient Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Fuse for Secondary Air Injection Pump blown
Vacuum Hose(s) leaky
Piping between Secondary Air Injection Pump and Secondary Air Injection Valve leaking
Possible Solutions
Check Fuse for Secondary Air Injection Pump
Check Vacuum Hose(s)
Check Piping between Secondary Air Injection Pump and Secondary Air Injection Valve
17819/P1411/005137 - Secondary Air Injection System; Bank 2: Insufficient Flow
Possible Symptoms
Possible Causes
Possible Solutions
Check your fuse and hoses first Lee
Old 17th July 2024, 11:08 AM
Reviving a very old thread.
Which is the fuse for the secondary air injection pump? I can’t find it on the list in the handbook
Old 18th July 2024, 08:21 AM
Location #6 in the attached image. It's in the fuse box down in the drivers footwell.
EDIT: There is also a relay for it. It's position #4 in the second image of the relay panel in the electronics box in the plenum chamber.
Name:	Screenshot 2024-07-18 091955.png
ID:	30332   Click image for larger version
Name:	Screenshot 2024-07-18 092226.png
Last edited by steamship; 18th July 2024 at 08:24 AM. Reason: Added Relay Location Details
Old 19th July 2024, 08:51 AM
Thanks Sean!
Old 24th July 2024, 02:58 PM
Well, instead of seeking out the fuse, I used the VCDS and ran the pump. I could hear the relay clicking and the pump running in the air filter box, so I assume that’s all working.
Old 24th July 2024, 08:22 PM
An even better way to do it.
