Is it a slow lazy crank when hot? That was my issue when the earth strap had worked itself loose.
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
Always a pretty eager crank tbh. Not discernibly different to normal. It just doesn’t start. Did move it today to clean it a bit. And now it’s just refusing to start again. Ahhhh. Old cars.
2002 A8L 4.2 D2 FL2. |
Did you check the battery terminals and the earth strap underneath the front leg chassis leg? Was it an exterior wash, as that could be a pointer?
![]() Have had a look for the earth strap. Is on the attached ? It looks covered in all sorts of shi* which I guess doesn’t help. I did have a duff oil pressure sensor sorted last year which might have helped coat some of the car in oil I’m not sure. Have had a bit of a clean of the terminals. Tried starting in N. It was a wet clean yeah. So at least it’s a bit more shiny now. It just doesn’t want to go. Swings and roundabouts. Could be a contributing factor?! Bit of a puddle around the wiper motor area but I can’t see or feel any dampness elsewhere. The passenger footwell seems dry still. Still cranking happily but not started yet.
I think all the earth straps look like that. It's worth opening it up to see if the connectors are clean and free of any oxidation. The oil pressure switch shouldn't cause any oil spillage, unless they tried replacing it with the engine running.
I wonder if it would be worth checking out the ECU box in the plenum chamber, to see if there is any water ingress there, and if so, is there any oxidation on any of the ECU connectors. Although it doesn't seem to be a case of it not starting every time it rains or you wash the car, it would be something to rule out. EDIT: Do you have VCDS or some other way of scanning the car for error codes? Don't know why I never asked that at the beginning, as there may be something obvious from the codes. If you do, scan the car, save the log file and clear all the codes. The next bit is awkward (since it's temperamental at starting), but you then need to take it for a drive and scan it again (and save) to see what codes reappear.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 1st August 2024 at 09:37 AM. Reason: VCDS scan suggestion |
Thanks for that!
I haven't been in the ECU plenum yet actually, I'll have a look there next time and see how it's looking. I don't have VCDS, i did have an OBD II dongle a while back. I could get an app on the phone and see if it reads anything. I noticed the orange TCS and check engine light were on during cranking but can't remember if these stay illuminated usually anyway?
vcds is a must...anything else is simply guess work.
if you are cranking over and no start then the autobox inhibitor could be at fault but please VCDS first is a must |
