Old 27th August 2024, 09:16 AM
Have you has a read through of the following PDF from the D2 Tech Dump thread? It covers all the suspension parts, but not exactly in the way you mention i.e. a complete rebuild as opposed to broken down into individual parts.
Service Manual Running Gear FWD and 4WD.pdf
The timing belt is a DIY job, so long as you have the correct locking gear and the patience to check your work. I did my first complete change last April (2023), and now have to do another change because the belt is moving a couple of mm. Despite going for 'quality' brand names, unfortunately a lot are now being made in China, so you can't even go by brand name, unless you know where they were made (see photo below).
BTW I come from an IT background and never worked on any car until I bought the A8. Like yourself, money is tight, and no one here in NI will even look at the car. One exception... and that didn't go well.
Old 27th August 2024, 03:51 PM
Marty Marty is offline
thanks for the pdf doc, this really helped.
dropped the car off at my local garage, for now I might just fix the knocking control arm and then in the future do the lot!
