Go Back   A8 Parts Forum > A8 D4 > D4 - Engine Bay
D4 - Engine Bay Everything under the bonnet
Old 7th March 2025, 06:33 AM
Horrgakx Horrgakx is offline
Very informative, thanks. Where do you find this stuff?
A8L W12 (D4 2015)
Old 7th March 2025, 07:58 AM
Found out about it when I had the D3 S8.
Old 7th March 2025, 09:55 AM
I don't see anything obvious which says ECU2 and there's only that single fault code relating to it, which I can clear, but the fault comes right back.
There is no visible effect on the car that i can pick up as a result of this fault.
A8L W12 (D4 2015)
Old 7th March 2025, 12:02 PM
Try connecting manually to ECU2, I think it's address 11. ECU1 is 01.
Old 9th March 2025, 09:11 AM
If I go to address 11 I see the fault code in there, and can clear it, but it returns. I can't see anything else in there. Am I missing something?
A8L W12 (D4 2015)
Old 9th March 2025, 01:15 PM
What is the specific fault code that's showing in ECU 2? Are you able to include the full part of Address 11, as opposed to just the fault code line itself?
Old 17th March 2025, 10:00 AM
Sorry I've only got around to this. Here's channel 11 log;
Address 11: Engine II (J624) Labels:. 07P-906-023-V1.clb
Part No SW: 07P 906 027 A HW: 07P 907 309
Component: W12 6.3 EU6 H22 8556
Revision: 41H22000 CVN: 077AE0AA
Coding: 002A0012256601000800
Shop #: WSC 23485 002 1048576
ASAM Dataset: EV_ECM63FSI21107P906027A 001011
ROD: EV_ECM63FSI07P906027.rod
VCID: 303ECF06AAA4CF7A3F1-8064
1 Fault Found:
24749 - Exhaust Pressure Control Valve 2
P04A2 00 [00100111] - Short to Plus
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 120237 km
Date: 2025.03.06
Time: 16:38:05
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 90 C
Intake air temperature: 45 C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.203 V
Unlearning counter according OBD: 40
Engine torque: 0.0 Nm
Fuel level: 28.00 l
Intake camshaft B1 active operating state: 0
A8L W12 (D4 2015)
