Hi all
One of my keys seems to have stopped working. Have changed batteries etc but here is the odd thing. When I do the reprogramming sequence all works fine but the key that was working (used to turn on ignition for reprogramming sequence), then stops working and the one I programme, is fine. Then I try the sequence with the one that has stopped working, and that one is fine, and the other one won’t work anymore. Basically I can only ever have one of the two keys working! Anyone got any ideas?? Thanks Mossy
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust. |
It's a long time since I tried reprogramming remote key fobs myself but, according to my notes, these are the correct procedures that worked. I do remember it's a bit of a faff, and it can take several attempts to get it right, especially if you have 2 or more fobs to program.
(Note the additional step required to program multiple remote fobs) Quote:
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 1st November 2019 at 07:35 AM. |
I also found this in my notes, but I don't think I've ever tried it (I'm not even sure where this info originally came from):
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 1st November 2019 at 07:33 AM. |
That’s brilliant thank you. Will give it a go later on.
I’m trying the above process (not VCDS) but with no joy at all. I’m confused at 2 points: at which press of the unlock button do you push it more than once; and do you press it twice for the second key as you obviously already have one key that works to have got into the car. Or, if you want a total of 3 keys to work, do you press it 3 times for each programming?
And which key is being programmed? The one in the ignition I assumed, but that could be wrong, I suppose. I know something is working as, although I’ve failed to programme a second key, another key that previously worked, doesn’t any more!
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .Planned mods: auto-dimming rear view mirror, dash cam (as steamship's), fit the ski hatch, refit philips drl's (or maybe not - nope, definitely not - horrible botch!). Last edited by The_Laird; 2nd April 2025 at 01:29 PM. |
Reading through Marks instructions, I believe you are right that it is the key in the ignition that is being programmed. Since you already have a key that works, and that is the one being used on the door, then any additional keys being programmed will require multiple presses. If that theory is correct, then programming a second (2) key should be as follows:
1. New key in ignition and turned on 2. Lock car with working key 3. Press unlock button once and horn will sound (if you have a working horn), but you'll have the indicators flash anyway 4. Wait 6 seconds and press the unlock button, wait one second and press unlock again 5. Switch ignition off 6. Remove key from ignition and try. If you're programming a third key, then point 4 requires 3 presses, one second apart, and a fourth key requires 4 presses, one second apart. The only thought I have is how the key memory positions are determined. i.e. does it just fill the 4 memory locations in sequence as you program them, or does it fill them based on the number of presses at point four in the process. If you have VCDS, I think you can check to see how many memory positions are occupied, and I think it can tell you what position the current key is in. UPDATE: Decided to see if I could find where the key information is stored. Within VCDS, go to to Address 35, Central Convenience. Go to Measuring Blocks (08) and then select Group 003. In the second field, you'll see a 4-digit binary number. Any number with a 1 indicates that a key is stored in that position. I haven't figured out if it can identify which key is being used, as I need to find my other keys.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 3rd April 2025 at 09:08 AM. Reason: EDIT: Checking VCDS |
It does not matter which key is in ignition if you are only programming the remote part as only immobilizer part is read by the coil around ignition lock.
Also, if you are just resyncing remote that was already coded to car, you do not need follow the full procedure, this is only for new remotes. For resyncing the key that was already coded but has lost sync, for example if buttons have been pressed too many times while out of range, just lock the car turning key in the door, then press lock button on remote. If it was paired but then removed, then will need full procedure again.
I think, from information "gleaned" elsewhere Jim has 3 keys and has somehow messed up the immobiliser so one works (fully) and the other two not at all - they will not unlock remotely and when starting the car with them the engine dies immediately.
VCDS scan required..... ![]()
I really appreciate you guys giving up your time with this, but still no luck, I’m afraid. The second key that worked initially has magically begun to work, in that it starts the car, which keeps running, and the immobiliser symbol goes out. But Ainars’ advise to re sync the remote doesn’t work. And, Sean, there is no group 003, just 000, 001 and 002.
Still, at least I now have 2 keys that wil, start and run the car
That sounds like the second key resynced after whatever you do with the lock (one of mine did that a while back) but a VCDS scan really will tell you......
